585,754 active members*
3,672 visitors online*
    Jul 2013
    Amazon PCI Parallel Port Card That Works
    I have a SuperPid/G540 setup running Mach3 on an old Dell Optiplex GX620. Everything worked great except spindle on/off... I was having to do that manually. I assumed the issue was wiring or Mach3 configuration, since that was the only issue... bad assumption. Eventually I got around to testing the parallel port output pin voltage and it was 3.3Volts, not 5 like I read everywhere that I needed. Researching around, I couldn't find a readily available (e.g. Amazon prime) parallel port card that was known to work. So I rolled the dice on this $9 Shinestar branded card:
    https://www.amazon.com/gp/product/B079939BLV
    and it's working fine. I did install the parallel driver that came with it, disable the motherboard parallel port, set the driver for the new card to use LPT1 (LPT3 was the default), and update the card address in Mach3 ports/pins, but I gather that may be needed for any add in parallel port.
    It is a PCI (long motherboard connector) and not a PCIe (short motherboard connector) card. In my research, it seemed to me that my odds were greater at getting a 5 volt card if it was PCI rather than PCIe. Not sure if that's really true or not.
    Anyway, just FYI, and sharing info I wish I'd have come across when I was trying to sort this out.
    Jul 2013
    Re: Amazon PCI Parallel Port Card That Works
    Just came across an interesting diagram that seems to suggest you can determine 3.3Volt cards from 5 Volt cards by where the "key" (that open slot in the edge connector) is... 5 volt cards have the key towards the rear of the connector:
    https://i.stack.imgur.com/uQTmf.png
    So if you have to roll the dice on a card and can see a picture of the connector it has... I would think this would improve your odds a lot.
    PMDX sells a card that they guarantee to work with Mach3.
  1. Parallel port pci card
    By Dylwad in forum PlasmaCam
    Last Post: 08-07-2013, 02:15 PM
  2. Parallel port card??
    By skylanehku in forum Gecko Drives
    Last Post: 08-29-2012, 04:53 AM
  3. Parallel port add-in card.
    By Drools in forum Gecko Drives
    Last Post: 06-27-2012, 06:40 PM
  4. Which PCI parallel port card?
    By bead in forum CNC Machine Related Electronics
    Last Post: 07-03-2010, 07:32 PM
  5. laptop pcmcia parallel port works
    By craigtx in forum Computers / Desktops / Networking
    Last Post: 12-12-2007, 08:31 PM
