Hello,
I just got a 3.0kw Huanyang VFD and I am having issues with the potentiometer that came installed in the unit/.
I set up all the frequencies to 60hz and setup the motor configuration but when I hit start button and turn the potentiometer all the way all I get is 25hz.
I have checked all the setting according to the manual and everything seems to be correct. Also I did the factory restore with #13 an the 08 input the reprogrammed all the settings and sill get the same issue.
Any help would be much appreciated.
Andres
