585,919 active members*
3,736 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > R-8 AND MORSE 4 SPINDLES ON E-BAY
    Feb 2009
    152
    [B]Came across these ads on E-Bay for mill spindles- looks like a good deal for a DIY milling machine project.
    [/https://www.ebay.com/itm/332835192692B]
    Jan 2018
    1516
    Re: R-8 AND MORSE 4 SPINDLES ON E-BAY
    Quote Originally Posted by GITERDUN View Post
    Link doen't work.
    Check the number.
    Apr 2016
    100
    Just delete the B when you copy and paste.
    You just get the R8 spindle, not R8 and R4.
    CNC hobbyist since 2003.
    Current CNC hardware: Sherline/A2ZCNC extended, 4 axis X/Y mill and Sherline lathe
    Jan 2018
    1516
    What size machine you planning on?
    Have a look at Littlemachineshop.com and see what they have too.
    They have ones from the Sieg SX2 & SX3
    The SX2 one may be shorter than the one you looked at (unsure). Both would be able to use 35 & 30mm inner diameter AC bearings too.
    They do have drawings of dimensions somewhere.
  1. Why are keling ATC spindles so much more expensive than er11 spindles?
    By sburck in forum Automation Technology Products
    Last Post: 12-20-2019, 02:32 PM
  2. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  3. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
  4. Morse taper
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 09-04-2007, 12:04 AM
  5. Morse tapers
    By OCNC in forum MetalWork Discussion
    Last Post: 11-12-2006, 06:30 PM
