584,846 active members*
4,124 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > Fusion 360 to Planet-CNC MK3/4 controller POST PROCESSOR help
    Oct 2018
    Red face Fusion 360 to Planet-CNC MK3/4 controller POST PROCESSOR help
    Newbie here trying to find a way to generate reliable G-Code from Fusion 360 to be loaded to my PLanet CNC MK/3/4 controller. I have tried about 15 different Post Processors but either they run into multiple errors are generate G-Code that has a multitude of manual corrections that must be made. Anyone out there have a solution?
    Nov 2018
    Re: Fusion 360 to Planet-CNC MK3/4 controller POST PROCESSOR help
    deleted
    I am also looking for a post processor for the same setup. Did you find a good one? Please let me know.
    Feb 2011
    138
    I am using EMC2-Lnux pp and works ok until the zero Z axes is on top of the object, now I have modified the PP to stop writing G28&G53 codes. Only attrention is nedded to put the Z axe higher from object.
    Still this is not job done, because I moastly use Z on table (using vaccum table), and need for aditional futures like start vacc, cooling, etc.
