586,000 active members*
4,922 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Just strange.... - Too change g-code missing
    Jul 2013
    84
    Angry Just strange.... - Too change g-code missing
    Forum help here appreciated....
    Extract machinable features - all good (hole drill and rough + contour perimeter)
    post G-code all ok (TUP 10mm CRB 4FL 2 LOC)
    A. When I select TUP 6m CRB 4FL 2 LOC and post process all the tool change information disappears?
    BTW i usually remove the rough feature as its not needed, but regardless if it stays or goes once the 6mm instead of the 10mm is selected - only the jobber drill remains??????????
    Attached Files Attached Files
    Jul 2013
    84
    Re: Just strange.... - Too change g-code missing
    no takers?
    Jul 2013
    84
    Attachment 404030
    does station impact - this is the only thing i see different?
  1. strange error code
    By joeyjrc in forum Tormach Personal CNC Mill
    Last Post: 07-18-2017, 01:27 PM
  2. Strange code issue!
    By EmeraldIsleforg in forum Milltronics
    Last Post: 10-06-2016, 03:46 AM
  3. Steppers not missing but making strange sound.
    By jwolin in forum DIY CNC Router Table Machines
    Last Post: 05-15-2012, 12:39 AM
  4. strange hi low gear change solenoid malfunction
    By bushing1 in forum Haas Mills
    Last Post: 09-02-2010, 02:19 AM
  5. Strange Axis problem after Ballscrew Change
    By AKFALAR in forum CamSoft Products
    Last Post: 04-01-2009, 10:07 PM
