585,908 active members*
3,759 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Aluminum Extrusion CNC frame from china similar to CNCrouterParts.com?
    Apr 2013
    21
    I see many Chinese hobby cnc machines using 20x40mm aluminum extrusion, but I cannot seem to find any Chinese cnc machines that use the thicker aluminum frames like CNCrouterParts.com uses.
    I would much rather get a cnc machine that is made out of aluminum extrusions than the huge steel ones that weigh so much you need heavier machines to install and move around.
    I am getting a container load imported into USA in about 3 to 4 weeks and though I could add a cnc machine to the load.
    Apr 2013
    1899
    Re: Aluminum Extrusion CNC frame from china similar to CNCrouterParts.com?
    20x40 extrusions are far too weak fora CNC. I have never actually seen one, but my current 3D printer is built out of 30x60 and I would not like to build a CNC from that, let alone 20x40. My CNC is build out of 90x45 and I think that's the minimum. I agree that moving it around is not very simple, mine weights about 90 kg, but the heavier the metter in terms if rigidity and overall quality.
  1. solid aluminum vs 8020 extrusion for small router frame?
    By dixdance in forum Mechanical Calculations/Engineering Design
    Last Post: 05-26-2018, 01:06 AM
  2. Replies: 4
    Last Post: 03-11-2018, 05:19 AM
  3. Aluminum plate or extrusion for frame??
    By brutus_sp in forum Vertical Mill, Lathe Project Log
    Last Post: 02-19-2016, 05:32 PM
  4. Used 8020 or similar extrusion
    By remskm in forum Open Source CNC Machine Designs
    Last Post: 08-27-2012, 05:17 PM
  5. Replies: 271
    Last Post: 02-27-2009, 06:36 PM
