586,005 active members*
5,181 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Rack & Pinion X Axis Slipping/Binding on Big Used Mystery Machine
Page 1 of 2 12
Results 1 to 20 of 29
    Oct 2018
    15
    Question Rack & Pinion X Axis Slipping/Binding on Big Used Mystery Machine
    Hello, I'm very new to CNC. I started playing around with a little X-carve a while back and got some cool results, so I decided to get serious and go ahead and buy a 4'x8' used 3rd hand machine off Craigslist... I'm not sure how to categorize this machine, it looks pretty commercial, but doesn't have any manufacturer's info on it anywhere that I can see. So maybe it's DIY? The only thing I really know is that it used to belong to Virginia Tech.
    Unfortunately I don't have any paperwork on it, and I know nothing about electronics yet; but here's a quick video walk around that shows most components:
    https://youtu.be/0AfCRUMoQlg
    Anyway, I watched the Mach3 tutorial videos and felt like I had a rough grasp, so I went to test the accuracy of the axes, but before I got to that I noticed the X axis wasn't moving very reliably at all. (I had previously tested this machine before buying it, and all axes worked fine, and I ran a test part with no problems). I checked the diagnostics in Mach3 and everything seemed ok, no LEDS interfering, or error dialogues, so I took off the cover of the X-axis motor assembly thing, and now it seems to be a mechanical issue.
    As you can see in this video, the stepper spins with no problem, but the pinion doesn't always pick up that motion:
    https://youtu.be/-9lZOKGdGBE
    After I sprayed some lube into the rails and gears and it was moving very easily by hand, it started being even less reliable for some reason:
    https://youtu.be/5DSQmaaieew
    Since I'm a total novice and no plans were included with this machine I have no idea how that area is set up, and I'm afraid if I take out the wrong screws, the whole thing might fall off or something.... Is it obvious to you experts what's going on? Is there some screw or spring or something I can tighten up to make that pinion catch?
    Bonus Question: Can anyone tell me interesting stuff about this machine just by looking at the first video? Components good or cheapo? Anything to be concerned about?
    Really appreciate any help! I've got lots of plans for this thing!
    Jun 2018
    362
    Re: Rack & Pinion X Axis Slipping/Binding on Big Used Mystery Machine
    Looks like the shaft between the X axis pinion and/or pully to motor is loose. Screws may be missing or not tightened, there may also be a key in a slot at either or both ends that is missing or broken. The travel sounds noisy so there may be a shot bearing or two too. Remove the drive belt and test the movement, with and without the pinion engaged to the rack. Disconnectet power before testing :-)
    Oct 2018
    15
    Thanks for the info. I wish I had some kind of schematics for this thing though. I guess I just have to dig in a start taking things apart...
    Jun 2018
    362
    In your video you can see the shaft with the pinion does not move (sometimes) when you hear the motor start. This is mechanical. Being a stepper (sounded like it) based system with a parallel interface to a PC (I'm guessing), the wiring will be quite similar to most design like this. Find a few circuits that use a break-out-board (BoB), parallel interface and stepper drivers. Use the model number on your drivers (follow the wiring back from the motors) and feed those model numbers into Google - you'll probably find useful data.
    Study these then apply these schematics to your machine and note any differences.
    Oct 2018
    15
    Thanks again. I'll go to the shop today and start unscrewing things to see if I can figure out what the issue is. Luckily I think the electrical stuff is pretty new, as the seller said the machine was completely overhauled within the past couple years with new steppers and boards, etc., so hopefully I won't have to worry about that for a while. Here's hoping it's a loose screw...
    Oct 2018
    15
    So it looks like at least one of the problems actually was a pair of loose set screws on the pinion shaft thing. When I tightened those up the assembly got significantly harder to move by hand, and I became able to jog the x axis what I thought was quite reliably. At least it was much better than before, and it makes sense that those could have come loose in transit after driving it 3 hours on a trailer.
    So I made a test toolpath in VCarve and ran it, and it came out looking a little like those clock-drawing psychosis tests:
    https://i.imgur.com/MPYBguj.jpg
    At first when it was cutting the middle I thought maybe I just needed to re-calibrate the x axis as it just seemed to be stretching to the left,
    https://youtu.be/BdVSTOJyD1U
    but then it started skipping over material in the Y direction too, so I'm not sure exactly what's going on. Maybe it's slipping on both axes. There are also a couple spots on the rack that are noticeably harder to pass over when moving it by hand. I'm going to clean up the rust a bit next time, but beyond that I'm not sure how to get it smooth yet.
    Anything weird stand out to anyone?
    https://youtu.be/OpkJnardLic
    Jun 2011
    692
    Try lowering your speeds and acceleration and see if that improves things.
    Also, make alignment marks on all the shafts and pulleys so you can tell if anything has slipped.
    Apr 2003
    540
    It's likely loosing steps somewhere. You didn't say but does the gantry have a stepper on each side or does it use only a single motor and shaft to drive the other side's pinion? Either way check all of the set screws in all of the pinions and any couplers/connections. A little thread lock is advised. If you have dual steppers on an axis also make sure the steps per setting for each of that axis's motors are exactly the same. When you are loosing steps it's either a mechanical issue and likely something loose, or something is tight/binding and the stepper(s) are stalling. If everything is tight and there is no binding, then like already mentioned, lower the accel and cut speed and practice cutting a few circles. If it's working at lower speeds, you can slowly raise the speeds to find the limits for the machine.
    There are software setting that can also cause issues, but I'm assuming the original owner that those settings correct. Since you already found a loose pinion gear it's more likely things loosened up during transport.
    Oct 2018
    15
    Question Re: Rack & Pinion X Axis Slipping/Binding on Big Used Mystery Machine
    Thank you guys for the input, it has been very helpful in trying to narrow things down.
    I finally got to spend a day at the shop yesterday and tested out a bunch of stuff. I marked all the pinions and their shafts, as well as all the pulleys and belts. I halved velocity to 100 and accel to 20 in motor tuning for X and Y, and did the Axis Calibration to set the steps until they seemed pretty accurate.
    Then I started running a test pattern in cardboard so as to not mess up a ton of wood, and got some pretty bad results. These are all run at 50 IPM and 10k RPM with a new 1/8" ballnose.
    The inner squares seemed more or less consistent, but every time it got to the circle it freaked out and made a crazy sound, which you can hear in this video:
    https://youtu.be/f8ayAwRWmYc
    So after a couple of these I noticed that my marks on the pinions were all still where I put them, so those weren't slipping anymore. Then I took the covers back off the motor assemblies (yes there are 2 steppers on the gantry, one on each side) and noticed that ALL of my marks on the pulleys and belts for both the Y and X axes were no longer aligned. So I guess that crazy sound may be the belts sliding? I never ran a toolpath with the covers off to check.
    I also did another test where I found that a 1mm tapered ballnose wouldn't even jog along 1/16" deep through cardboard. Is this to be expected? I found metal chips in this thing, so I would think if it can cut aluminum, why would it get hung up on cardboard?
    https://youtu.be/hj10afsBGpM
    After all this, I decided to start taking things apart to check the bearings like he1957 had suggested to see if I could reduce the friction.
    This is the bearing that the Z-Axis and X-Axis motor assemblies run on (is there a word for this chunk of stuff that rides along the gantry? Gib?).
    And here's how it slides after a good solid clean and lube of the rail:
    https://youtu.be/iO2fpLjKmjE
    It doesn't seem too bad to me, but I have no idea what I'm shooting for. Still plan to do a rust-removal treatment next time to get the last traces off the rail.
    Also checked the X-axis pinion by hand, and found it to be gummy, inconsistent, and sometimes fairly hard to turn.
    https://youtu.be/rUZhZ594Uj8
    I pulled it off the shaft to check the bearing the shaft goes through, thinking that might be an issue, but didn't have enough time to fully disassemble that part yet.
    So that's my update for this week. Any more ideas? Thanks again to everyone who has weighed in so far!
    Questions Summary:
    1. What's the weird sound? Belts slipping?
    2. Why are belts slipping?
    3. Why can't I jog through cardboard with sharp bit?
    4. Are these bearings shot? Or just dirty?
    Edit: Looking back at my own videos, I think I'm probably a little retarded, and when I say I marked the pinions, I probably was marking 2 spots on the same piece of metal since the gear is also part of a hollow shaft that the other shaft goes into (at least on the x axis) so those may be slipping as well...
    Jun 2011
    692
    Marks on the belts won't necessarily align with marks on the pulleys unless the number of teeth on the belt is an integer number times the number on a pulley. If the belts actually are slipping it's because they aren't tightened enough or the belt or a pulley is really worn or damaged (teeth missing or worn down.) On that video dragging the 1/16" mill through the cardboard did you look at all the shafts to see what was slipping? It doesn't sound like a belt slipping or stepper missing steps to me.
    Oct 2018
    15
    Quote Originally Posted by skrubol View Post
    Well I guess that makes sense.... my badness in math and geometry has betrayed me it seems. Maybe the belts aren't slipping after all. Not even sure how to adjust the belts honestly, it looks like everything is just attached straight up to the same block of metal in fixed positions.
    I never did run a program or jog into a binding area with the covers off though. That's a pretty obvious mistake. That would probably tell me a lot, and I'll have to check it out next time to see for sure whether pinions or belts are slipping. That loud sound during the circle cuts seems like something pretty major though.
    Apr 2003
    540
    I hate to get you chasing another possibility, but I didn't see in the thread what software you are using. I'm going to assume Mach 3 since it's pretty common. UCCNC also has some of the same settings. Anyway, there are a couple settings in Mach that can cause issues when cutting arcs/polylines. Instead of getting to far into specifics, do a little researching on CV (or constant velocity) mode and settings. Incorrect settings or values can cause some pretty strange cuts depending on your gcode output (G01, G08, G64 etc in your code). If the post processor you are using isn't "in tune" with your Mach settings it can cause issues. Some of the settings effecting cuts are constant velocity vs exact stop, look ahead, absolute or incremental. If the settings aren't correct for the output gcode there will be issues cutting IJ arcs vs polyline arcs etc. I've even seen strange things on straight polylines depending on the post processors output and Mach settings. Of course if this is a mechanical issue, this is all a moot point. But if you can save or write down all of your current settings before changing anything and do a little research on Mach's CV settings and taking a closer look at your gcode it may worth checking into.
    Jun 2018
    362
    The sound of that X axis manual move by itself is very loud and sounds like the bearings are shot. Take the plate off and try the individual trucks.
    The other thing of note is the change in pitch of the motors across travel; this seems evident in both X and Y but what's interesting is the timing - it seems consistent in a distance/time relationship. A bit odd me thinks.
    (The Z sounds a little tired too).
    If everything checks out mechanically, then have a look at your power supplies. For the circle components, both motors are running, drawing more current. Sounds like a power supply problem. If you have an oscilliscope, see if there is ripple on the DC power lines (bad filter caps). Failing the 'scope, try a DVM on the power lines and see if there is a variation of more than a few millivolts between load and no load, between just X, Y and X and Y together.
    I'm guessing there may also be a loss of power on one side of power delivery (A and B) but the machine is losing position.
    Try single X and Y movements + and - and mesaure the distance (with a ruler), rinse, repeat - perhaps that may show if lost position(s) is/are random or consistent. If consistent, check settings as per previous post otherwise mechanical/electrical - perhaps both?
    Belt adjustment is typicallly just a few elongated slots under the motor mount plate screws; there may not be much movement so if the belts have stretched, they may need replacing.
    Just a few thoughts.
    Oct 2018
    15
    Quote Originally Posted by coherent View Post
    Ok thanks for the idea. Yes I am using Mach 3. I should be able to get by the shop again this weekend to finish checking the bearings and pinions with another person helping, so I hope to either pinpoint or rule out a mechanical problem.
    The thing is though, the test program I ran at the guy's house before I decided to buy it was much more aggressive than any I've tried to run since, with a bigger end mill going deeper into harder wood, but it was going so well that I stopped the program before it got to the circular profiles, since it was looking like it might hit the clamps... so I'm not sure if the circle/arc weirdness is a pre-existing issue or not. If the circles would have worked at that time, then his settings should be fine now too I would think.
    That noise really bugs me though, it really seems like a mechanical slip or something, since it even vibrates the covers. Maybe both Y-axis pinions are slipping independently and creating some weird resonance... Who knows.
    dgolden Guest
    Quote Originally Posted by he1957 View Post
    Sorry, I didn't see this post until now. Very interesting ideas. I think you might have something with the power supply idea. Make sense that it's freaking out when 3 motors are running at the same time. No oscilliscope sadly, but I probably know someone with a voltmeter.
    I did calibrate x and y over a distance of 12 inches and on those single axes alone they seemed to hold the right calibration within 1/16" or less over the course of a couple tests, and I could zero out a home position, then jog all the axes individually and goto home and it would go right back to the same spot, but after running the test program it would get out of whack again every time pretty much, and after it was done the home position would be off by 1/4"-1/2" in x and y. Haven't done any calibration or testing of the Z yet, but it does sound a little squeaky.
    Oct 2018
    15
    Lightbulb Electronics
    Did a little googling on the electronic components, and here's what I've come up with.
    STEPPER MOTORS (Photo):
    Keling Technology
    https://www.automationtechnologiesin...l34h295-43-8a/
    NEMA34 HIGH TORQUE STEPPER MOTOR 906 oz-in
    KL34H295-43-8A (1/2" Single Shaft)
    906 oz In. Hybrid Motor
    1.8° /200 Steps Per Rev.
    6.1 Amps Current Per Phase (Bipolar Parallel)
    8-wire Bi-polar or unipolar,
    NEMA 34 Frame
    DRIVERS (Photos):
    Keling Technology
    https://www.automationtechnologiesin...rivers/kl8060/
    KL8060 Digital Bipolar Stepper Motor Driver 24-80VDC 6A - 32 bit DSP Based
    1: Supply Voltage 24 up to 80 VDC
    2: Dip Switch Setting (Current): 2.0,2.57,3.14,3.71,4.28,4.86, 5.43, 6.0A
    3: Dip Switch Setting (Micro Step):
    2,4,8,16,32,64,128,256,5,10,25,50,125,250
    3: Suitable for 4, 6, 8 wires motors
    5: Full or Half Current Mode: Sw4: 0= Half Current
    6: TTL compatible and Optically Isolated Signal I/O
    7: Short-voltage, over-voltage, over-current and over temperature
    protection
    8: Pulse input frequency up to 400 KHz
    9: Support PUL/DIR
    BREAKOUT BOARD (Photos):
    C10R10.1-S688-46
    https://cnc4pc.com/Tech_Docs/C10R10_USER_MANUAL_V2.pdf
    DIGITAL INPUT SPECIFICATIONS:
    On-state voltage range - 2 to 5V DC
    Maximum off-state voltage - 0.8V
    Maximum operation frequency - 4 MHz
    Typical signal delay - 10nS
    DIGITAL OUTPUT SPECIFICATIONS
    Maximum output voltage - (5V power supply voltage) + 0.5V
    Typical output current - 24mA
    Maximum off-state voltage - 0.44 V
    Typical signal delay - 10 nS
    Time of transition to high impedance state - 12 nS*
    POWER SUPPLY (Photo):
    (I think?) KL-7220, 72V(No load), Max 20A,Unregulated Power Supply, 110VAC/220VAC
    https://www.automationtechnologiesin...-4-axis-kit-7/
    I'm guessing the guy who recently replaced the electronics purchased the kit at that link, which includes the same drivers, breakout board, and motors, and then just got an extra motor and driver for the A axis. However, the power supply does look slightly different on mine, with more heatsink fins and some additional "stuff". Sorry, complete electronics noob.
    ROUTER
    PORTER-CABLE 75182 Variable Speed Router Motor
    https://www.amazon.com/PORTER-CABLE-.../dp/B0007SXHXM
    Amps - 15 Amps
    Collets - 1/2 in
    Horsepower - 3-1/4 HP
    Motor Diameter - 4.2 in
    No Load Speed - Soft starting 5 speed at 10,000, 13,000, 16,000, 19,000, and 21,000 rpm
    Power Tool Type - Corded
    Here's the video tour of the box:
    https://youtu.be/hFHDHrjLuwo
    Again, I'm still pretty clueless when it comes to electric, but from what I understand this is plugged into a 110v 20amp circuit. The guy who sold it to me was pretty clueless too, all he said was "it will run on normal house electric, just make sure you have it on a big breaker"
    So... from these specs, should it be OK on the circuit I'm using it on?
    Oct 2018
    15
    Real Progress
    Had a pretty successful day at the shop. Took off the X-Axis rail and did a de-rusting treatment, and greased up that and the bearing, which seemed ok, just a bit gunked up. Found out that the motor mounts have no allowance for adjustment at all, they screw right into threaded holes in the plate. After taking the motor off the belt though, that bearing for the pinion axle or whatever spins freely, so that's not a problem.
    We put the motor and belt back and reattached the pinion and tightened the set screws again, and put it all back together to run a test with the covers off to see if anything was slipping. Tried the cardboard test several times without moving anything, and it ran perfectly inside the grooves it cut the first time around without losing the home position. Tried it with the router plugged into a different 20 amp circuit and it didn't seem to make any difference.
    So we decided to do a test in wood, and behold, for the first time, it ran a longish test program with no problems. None of the belts or pinions or axles seemed to be slipping. In the end the overall width of the circle varied ever so slightly, so I re-calibrated all axes to be less than 1/16" off over 40" in X and Y and less over 3" in Z.
    Then ran a real test program with a rough in pass, which still gave those weird noises on the circular profiles, but didn't lose position:
    https://youtu.be/SJoCTMvFuik
    and a finish pass, which seemed to run perfectly.
    https://youtu.be/yWWnPux5E1M
    Unfortunately, shortly after the end of that video, it started screwing up again. I think the cable carrier chain was off by 1/4" or something and smacked into the Y motor and knocked the pinion loose again, so here is the final result.
    So it looks like it was that simple after all. Just set screws knocked loose in transit... fingers crossed. Going to go back next time and put some blue loctite in those set screws and de-rustify the Y axis rails and try a few more intensive tests.
    Thanks again for all the input and help, and I'm still happy to hear any more insights and advice if anyone thinks of anything.
    Apr 2003
    540
    Glad you seem to have found the issue. It's not unusual to not have any motor adjustment on a direct to screw drive setup. The motors are mounted exactly in line with the screw/shaft and any adjustment between the motor shaft and screw is at the coupler which is normally a 3 piece type with a nylon or plastic hub in the middle, or a one piece that is flexible. I'd recommend oldham type as they compensate for misalignment while still being very precise. Solid type are ok, but only if everything is aligned absolutely perfectly so are rarely used in CNC machines. The spiral flex type are polular on small machines but tend to fail/break more easily in my experience.
    If you had to "de rust" things you may want to do a thorough job of cleaning and lubing and/or replace anything that's an issue. Everything should be clean and well lubed. Rust, friction and dirt etc don't play well with precision, smooth CNC machinery operation as you have already found out..
    Apr 2004
    733
    Make sure you put some good grease on those linear rail ball bearing carriages. I use THK AFC grease on my linear carriages but it is rather expensive stuff. Mobil EP1 is a decent alternative. I bought a tube from Granger for about $8.
    Oct 2018
    15
    Problem Probably Solved
    I'll definitely look into the oldham couplers for the Z axis, which is on a direct to screw setup. Right now I think it's just in a sleeve with set screws that connects the motor shaft to the screw in line. Probably not the best, but haven't noticed any issues just yet.
    Everything else besides the Z axis is on rack & pinion and driven by a belt setup like this which runs from the directly mounted motor to a shaft that goes through a press-fit bearing which looks like this on the other side, except normally with a pinion gear on that shaft. So there's no ability for adjustment that I can see there, except for just changing belt size. Either way the belts aren't slipping after all it seems.
    As you can see in that last picture, and more clearly in this one the X axis pinion set screws must have been slipping for a while, since they have worn a groove in the shaft. I didn't notice this before, but a friend pointed it out, and you can see that the shaft wore down the cupped ends of the set screws as well. So I'm guessing the last owner who was also a novice just kept tightening them down, and not using loctite or anything, and it kept wearing things down more and slipping.
    So we got some brand new set screws, and put them down into that groove and set with loctite. Then after waiting a cautious 24 hours, ran the same test that slipped halfway through last time and got a better result outside of a somewhat poor surface finish. So it seemed to do the whole thing with no real problems. Still have more tests to do though, and over a larger area.
    Quote Originally Posted by jfong View Post
    Last weekend we cleaned all the rails and took all the motors off to test the bearings, and all 4 linear bearings on the Y axis were pretty much silky smooth after removing the surface rust on the rails. We have packed all the linear bearings and greased the rails with white lithium grease which I saw recommended elsewhere, as we happened to have it in the shop already, and things seem to be quite a bit smoother and quieter now. We'll see how it holds up over time, and I'll make a note of the ones you recommended for future reference.
    Thanks again for all the help and recommendations!
Page 1 of 2 12
  1. Ballscrews or rack and pinion? What module of rack and pinion is the best?
    By masinecc in forum DIY CNC Router Table Machines
    Last Post: 04-13-2015, 06:04 PM
  2. Rack & Pinion binding
    By benkrall in forum FineLine Automation
    Last Post: 09-29-2014, 07:16 PM
  3. Solution to stop slipping on Rack and Pinion
    By mikefalkner in forum DIY CNC Router Table Machines
    Last Post: 05-15-2014, 08:06 PM
  4. Rack and pinion x axis
    By thunderdork in forum DIY CNC Router Table Machines
    Last Post: 07-28-2013, 12:21 PM
  5. Rack and Pinion for x, y axis question ???
    By zeoncomp in forum Waterjet General Topics
    Last Post: 09-22-2007, 03:19 PM
