585,762 active members*
4,376 visitors online*
    Jan 2007
    76
    Linear glass scale pin 9
    Just completed building and testing electronics for the Yuri Touch Dro system.
    Originally thought about using rotary encoders with 600 ppm operated by wire but when thinking more about it, resolution is too low.
    Looked at glass scales with ttl output and wondering what is the pin 9 I see in many instances.
    Can see 0v, 5v, shield connection, A and B outputs but the pin 9 has me stumped as to what it is used for.
    https://ncmaster.com.au/ncmaster/ind...product_id=444
    Feb 2008
    644
    Re: Linear glass scale pin 9
    My guess would be Reference = Z = Index
    Nov 2012
    1267
    What he said. Reference (index) signal.
    Jan 2007
    76
    OK...thanks for that.
    Another query....
    Linear scale supplier quotes output as "TTL square /wave EIA-442" so I imagine if I only need the TTL signal, just use A and B out?
  1. Glass Scale
    By whagkangmakulet in forum Fadal
    Last Post: 09-25-2017, 11:07 PM
  2. Linear Glass Scale encoder with Kflop/Kanalog
    By PeterMouse in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-24-2013, 05:14 AM
  3. Linear encoder / glass scale on manual knee LINUXCNC / EMC2
    By will gilmore in forum LinuxCNC (formerly EMC2)
    Last Post: 07-03-2012, 03:30 PM
  4. linear glass scale error?
    By beezerlm in forum Uncategorised MetalWorking Machines
    Last Post: 03-23-2006, 05:40 PM
