Hello to all,
I have built a cnc machine out of steel 1/4 inch thick 2x4 tubing, all welded in the intention of cutting wood, but also occasionally aluminum and steel.
However, I need to choose a spindle and here are the following candidates from the available Chinese spindles:
- 2.2kw ROUND - water cooled - air cooled
- 4kw ROUND OR SQUARE - water - air cooled
From all the videos and research I have done, it seems like the SQUARE spindles are louder and more high pitched than round spindles, but I don't have experience with either and would appreciate if someone can confirm this.
Also, the SQUARE spindles have a longer shaft than the ROUND ones, could this cause more stress on the bearings when milling steel since the bearing are not even designed for steel to begin with.
Its just that I need to make really small and precise parts and most videos making such parts show 2.2 kw ROUND spindles.
Others have told me that they are not powerful enough requiring to cut very shallow depth at a time which takes so much longer than having a 4kw spindle.
All help would be so much appreciated from all
Thanks in advance
Sam
