584,849 active members*
4,373 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal model 914-10B vector drive parameters lost!
Results 1 to 8 of 8
    The vector drive backup battery got faulty and lost the parameters. The unit is a INV-49. If anyone have the parameters and can help I would apprecciate it.
    jolulank
    www.doctornumerico.com
    cnc physicians
    Jan 2015
    417
    Re: Fadal model 914-10B vector drive parameters lost!
    Posting a picture of your drive will help. Is it a mitsubishi?
    Jan 2015
    417
    This should work here are the settings http://itscnc.com/images/Spindle_Drive_and_Motor.pdf
    Sorry about that.
    It is a baldor vector drive INV-0049[Attachment 404150
    cnc physicians
    Thanks Rodney, that might do the trick. I will give it a try tomorrow
    cnc physicians
    Jan 2015
    417
    ITScnc.com sells the baldor drives so if anyone would have them it would be them
    Feb 2007
    171
    Sir,
    If you have lost your parameters on the Baldor drive in the photo, you need a new inverter. The parameters are loaded into the drive via an EPROM during start up. If they are not loading, you have a problem with your processor board inside the drive. Those older Baldor drives are no longer in production and parts are about non existent. If you load the parameters each morning, you can run but this is a real pain after about the second time you do it.
    We don't have an old INV-0049 but we do have a replacement Yaskawa or Glentek that plugs right in.
    FadalCNC Tech Support
    The Baldor drive does have a cr2032 that holds
    The parameters un it. I just replaced it with
    a new one and it works fine again. No new drive
    needed
    QUOTE=ASIGuy;2227288]Sir,
    FadalCNC Tech Support[/QUOTE]
    cnc physicians
  1. lost pmc parameters for SMG model V32 mill and backup
    By icetp in forum DIY CNC Router Table Machines
    Last Post: 09-18-2018, 12:47 PM
  2. Replies: 21
    Last Post: 09-04-2015, 02:36 PM
  3. How to export vector as 3d Model
    By Saeed83 in forum ArtCam Pro
    Last Post: 01-01-2014, 09:37 AM
  4. Replies: 0
    Last Post: 09-07-2013, 11:05 AM
  5. 3D model vector drawings
    By Ideas L in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-24-2008, 08:43 PM
