585,982 active members*
4,563 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > having problems getting laptop to communicate with 100w co2 laser from ebay?
    hi I've received a co2 laser today, its 100w from ebay (made in china) I am new to this and installed the disc with lasercad but am having trouble getting my laptop to communicate with the laser machine. Any help or advice out there? I couldn't seem to install the CorelDraw that came with it?
    Sep 2018
    83
    Re: having problems getting laptop to communicate with 100w co2 laser from ebay?
    It likely didn't come with CorelDraw - what would ahv been bundled is a plugin that integrates the laser functions into an existing installation of CorelDraw.
    You say you've installed the software for the laser - does that also include the driver? If not, install the driver that's appropriate to your version of Windows. I'm not familiar with LaserCAD, so I can't really advise how best to get it set up to talk to the laser, I'm afraid.
    Feb 2016
    21
    You will need to install corel first then the plug in on the disk that came with the laser. Laserdraw should work, have you put the key in your laptop? Its like a gold usb, this has to be in a spare usb port on your computer while connected to the laser, or they wont talk to each other.
    Is this a laserwork software orlasercut software ?
    usually CorelDraw software is not included
    https://www.automationtechnologiesin...level-machine/
  1. 50W Chinese Laser Doesn't Communicate :(
    By roig12 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-19-2018, 07:37 AM
  2. Mach3 breakout from eBay, no laptop parallel port
    By travis_farmer in forum CNC Machine Related Electronics
    Last Post: 04-14-2017, 12:48 AM
  3. Fagor Communicate with laptop or anything!
    By gaanes in forum Fagor Automation
    Last Post: 12-22-2009, 05:07 PM
  4. usb only on my laptop, can i still get an rs232 cable to communicate
    By iknownothing in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2008, 08:27 PM
