Hello everyone,
I have a problem with a Masterwood Project 327 (1998 - Dos control MW309 - CN10).
I had not used this machine for several years.
When put back in function of the machine, plc no longer worked, so I made a Shift + PARM and sent the PLC.
Until all is ok, and now I have a code 0.0.0090 (emergency stop), I tested the electrical wiring and everything
is OK. The air pressure is ok, ...
When I try to reset with the white button, it turns on for a few seconds and is off ...
How is it possible to control that the plc is well loaded and works well?
Thank you in advance for your answers
