585,555 active members*
3,441 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Where to source ballscrews and nuts
Results 1 to 7 of 7
    Oct 2018
    79
    If any-one could suggest where is a good place to buy ballscrews and nuts for a PM-30 or PM45 sized milling machine that would be appreciated. I'm trying to cost things up cheers
    Oct 2018
    79
    Re: Where to source ballscrews and nuts
    OH I'm in the UK if that makes a difference.
    When sizing ballscrews as I don't have a lathe do I need to request thay they are cut/finished as required? (i'm not sure what that involves)
    Quote Originally Posted by men8ifr View Post
    We have the PM30 ballscrew kit ( othe G0704 kit, PM-25MV Kit) in stock
    https://www.automationtechnologiesin...ll-screws-kit/
    https://www.automationtechnologiesin...0-pm-25mv-kit/
    Apr 2003
    540
    I have Automation Technologies double nut/ballscrew kit on a Grizzly mill and am pleased with the precision and quality. You can source the same screws and nuts from China on Ebay which many have done with success and save a few $. If you don't have a lathe or want to mess with fabricating the thread/mounts yourself, many will also cut to size and turn/thread to your specs for very reasonable. The kits simplify things and the ones Automation Tech has with the screws sized for specific machines are pretty much ready to mount. You'll likely need to mill out some space on the bottom of your table for the nut to fit. I had another mill handy when I did mine, but many have used a grinder or other means.
    Oct 2018
    79
    Quote Originally Posted by automationtechinc View Post
    Ok thanks, what is the spec on the screws and nuts? I see the nuts are listed as DUF but I don't understand what that means cheers.
    Apr 2003
    540
    I believe the SUF are the single nut version and DUF is the double nut. The double nut setup is more accurate/less backlash.
    Oct 2018
    79
    Is the X screw 16mm and Y,Z 20mm? (it looks smaller in the photo) is that to allow fitting without machining the saddle?
    All 5mm lead thanks
  1. Replies: 4
    Last Post: 07-20-2015, 12:36 AM
  2. Where can i buy ballscrews, icl. nuts an bearings ?
    By 19roomer68 in forum Linear and Rotary Motion
    Last Post: 06-17-2012, 02:46 AM
  3. possibly good deal on ballscrews/nuts
    By KTP in forum Uncategorised MetalWorking Machines
    Last Post: 03-14-2011, 06:57 PM
  4. GMT Ballscrews + Poll: Double vs. Single Nuts
    By Glacern in forum Linear and Rotary Motion
    Last Post: 12-05-2009, 06:15 PM
  5. Supplier for ballscrews,nuts for Zay conversion
    By davo727 in forum Benchtop Machines
    Last Post: 02-01-2007, 01:20 AM
