586,009 active members*
4,787 visitors online*
Results 1 to 3 of 3
    Jan 2011
    10
    Spur gear tooth profile
    Hi all
    I am trying to machine a spur gear, 20 deg, module 2...
    Gear 1 with 35 teeth
    Gear 2 with 85 teeth.
    The sales person for the inserts says that the gears will have different tooth profiles because of the 2 different Diameters and number of teeth. .
    As far as I know, there is no difference in tooth profile for the same module... Can anyone please confirm this?
    Feels like he is trying to make sales...
    Clauds
    Sep 2006
    245
    Re: Spur gear tooth profile
    Involute gear cutters need slightly different cutters as the number of teeth changes. The tooth profile might be similar, but you are cutting the space between the teeth, instead of actually cutting the teeth.
    Typical involute gear cutter sets could have different cutters for gears with the following tooth counts
    #1: 12-13
    #2: 14-16
    #3: 17-20
    #4: 21-25
    #5: 26-34
    #6: 35-54
    #7: 55-134
    #8: 135 or more
    Note: some companies label the cutters 1 through 8, others label them 8 through 1. The effect is the same. Each cutter is designed for a small range of tooth counts. The 35 tooth gear should be cut using a #6 cutter and the 85 tooth gear should be cut using a #7 cutter.
    You will have less than optimum results if you cut both gears with a single cutter. It may still be functional. Friction may be slightly higher or backlash may be slightly different than expected.
    Mar 2015
    409
    I make my own gear cutters (fly cutters) for some years now. I started making them on the milling machine using the button method. In stead of using the "button", I use an end mill to machine the cutter. Nowadays, I turn the gear cutter on the CNC lathe. This only takes a few minutes. Because it is so fast and easy to do, i turn a cutter for the gear (tooth count) to make. I use silver steel that can be hardened by heating it up (cherry red) and then quench it in water or oil.
    Look at this site for more information and the formula's to calculate the "button" parameters. Designing gear cutters - mikesworkshop
  1. Replies: 0
    Last Post: 12-31-2016, 04:45 AM
  2. Ningbo San min gears. Spur gear. Timing belt and pulley. Rack gear.
    By ningbocctv in forum Manufacture Company Listing
    Last Post: 12-08-2016, 11:25 PM
  3. Trying to find a gear tooth profile generating software.
    By Zenji in forum Mechanical Calculations/Engineering Design
    Last Post: 06-12-2014, 11:48 PM
  4. Bevel Gear Cutting with Involute Spur Gear cutter
    By basalt in forum MetalWork Discussion
    Last Post: 05-06-2012, 10:13 PM
  5. calculating tooth thickness in spur gears
    By coykiesaol in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2010, 04:08 PM
