585,712 active members*
4,235 visitors online*
    Jul 2003
    Free Doors--Free Cabinet Door Software
    NOTE: This was originally a ShopBot only program but has the output has been expanded to include G-Code and DXF and should be relavent here.
    Dear Free Doors Users:
    I have finally updated the Free Doors website to include the latest Free Doors 4.0U Beta installer. This includes the latest Doors.EXE from Mike Richards, the new Cutters Editor (taking into account the feedback that I got from the early alpha testers) and the UNIVERSAL version of Free Doors. Free Doors now exports ShopBot code, G-Code, and DXF format.
    The website address is:
    http://home.centurytel.net/bwclark/
    I have also updated the "Getting Started Tutorial" to include how to use the Cutters Editor. So, please read that FIRST! Also, I am including the updated portion of the FreeDoors_ReadMe.TXT file, which included some more indepth information about the Cutters Editor.
    Bruce Clark
    PS Did I mention, it is currently free?
    First off, I would like to thank Michael Richards for making his cabinet door software available to everyone. THANK YOU!
    What's New? [04-30-2007 Version 4.0U]
    It has been a while, but the wait should be worth it. There are some major changes to Free Doors. First off, Free Doors now supports G-Code and DXF file exporting. G-Code opens up Free Doors to be usable by a lot more CNC router machines. The DXF option allows you to open up the cabinet door paths in a CAD/CAM program for further embellishement such as V-Carving (we like VCarvePro by Vetric www.Vectric.com) or 3D carvings.
    Since you have a choice if 3 types of output, you are also offered a choice of "Previewers". The ShopBot previewer we recommend is the ShopBot control software. This portion of the program has stayed the same--it opens up the ShopBot control software in the preview mode. For the G-Code, if you are a MACH controller user, use your Mach software (www.artsoftcontrols.com) or, as we recommend, NCPlot 1.1. It is FREE and it integrates very nicely with the FreeDoor's preview. It is available here: http://www.ncplot.com/ncplotfree/ncplotfree.htm . As for the DXF, any CAD/CAM program that can accept a command line file name, can be used to preview the DXF output. If not, just select something like Notepad.exe. With the way the program is currently implemented, you need to have a program selected. It does not matter which, but something.
    The choice of cutters for Free Doors was a major sticking point with a lot of people. Mike's original tools, while commonly available, where not that common to a lot of users. Also, tool depths, tabs, and sizes were a big "trial and error" in getting the settings correct. This has been made a lot easier with the new plug-in called "Cutters Editor". This CUTTERS.CSV editor allows you to "preview" what the groove between the panel and the stiles and rails will look like without being at your machine. You can experiment with different size cutters, tool types and depths. When finished, you can save your tool set (tool selections and all) for a later recall. This also allows for different tool settings for different jobs (make a copy of your new tool set and then copy--or save--the tool set as CUTTERS.CSV so that Mike's DOORS.EXE can find it).
    Also, if you want to preview what a special tool's cutting profile will look like, you can create it (if it does not currently exist) with any CAD or drawing program that can export DXF files. To make a custom tool profile, you need to draw it at true to life size AND the cutting point or tip must be at 0,0. Otherwise, the tool will be draw off location in the preview. For a better explanation, please open one of the provided DXF tool profiles in your CAD/CAM/drawing program. The V-Bit tool is the best example.
    Lastly, Mike has updated his doors.EXE program to 7.14b. This has a few enhancements and some cleaned up code.
    This release is BETA but we feel it should be stable enough for production work, if that is what you are using it for.
    Oct 2005
    267
    Hi Bruce,
    I got the program and it seems to work great. I just need to play with it some more so I can get into some real design work. I wonder if I can import my own graphics to the program or do I need to design cabinet doors first and then export them to a dxf file and then import the design as an overlay then merge the two together? Then what would I need to generate the tool paths and g-code?
    Greg
    Quote Originally Posted by 1BigPig View Post
    Bruce Clark
  1. Free Cabinet software
    By Ryan P in forum News Announcements
    Last Post: 01-22-2021, 01:17 PM
  2. Free Software
    By CNCRob in forum Uncategorised CAM Discussion
    Last Post: 12-31-2012, 02:53 PM
  3. Free CAD software
    By ynneb in forum Uncategorised CAM Discussion
    Last Post: 07-08-2011, 12:35 PM
  4. Single Route MDF cabinet doors
    By Puritan-KY in forum Employment Opportunity
    Last Post: 05-17-2010, 02:14 PM
  5. Free X-CAD Software
    By CarveJunky in forum Uncategorised CAM Discussion
    Last Post: 06-30-2005, 08:55 PM
