585,762 active members*
4,249 visitors online*
Results 1 to 2 of 2
    Nov 2008
    Mach3 Help (please) Z clearance plane warning
    Hi All,
    Desperate for some help...
    We have a simple Cobra router that we use to cut foam for boxes. We only cut 2 thicknesses of foam and have not any limit switches fitted. To set the Z height before we machine a foam we have a touch plate. I've designed a part in Fusion360 and used the G code from the CAM function. All worked fine, we then tried to go back to our foam cutting and now the Z probe doesnt work and we get an error message that the Z clearance plane is above the Z axis home switch. I've checked in the soft limits and they are set to 999 so I don't see what the problem is.
    I think the issue is that the fusion file added a line G43 which I believe is a tool length.
    Can anybody help me to clear this please??? Ive checked in the tool library and they are all set to Zero.
    Mike
    35538
    Re: Mach3 Help (please) Z clearance plane warning
    That's a message from the 2010 Screenset.
    When you first start the machine, jog the Z axis to the top of it's travel, and click the Home Z button.
    That will set your Z axis home position to the top of the Z axis.
    The macro is trying to prevent the Z axis from crashing into the top of it's travel.
  1. R clearance plane error
    By popspipes in forum Tormach PathPilot™
    Last Post: 02-06-2018, 08:22 AM
  2. Pockets and clearance plane in CamBam
    By CitizenOfDreams in forum CamBam
    Last Post: 08-06-2016, 05:11 PM
  3. Feedrate moves at clearance plane?
    By DMaz in forum BobCad-Cam
    Last Post: 07-10-2015, 11:02 AM
  4. how to adjust rapid plane clearance
    By hmoore01 in forum BobCad-Cam
    Last Post: 03-18-2014, 05:16 PM
  5. Default clearance plane
    By BurrMan in forum BobCad-Cam
    Last Post: 02-21-2014, 05:42 AM
