585,715 active members*
4,622 visitors online*
IndustryArena Forum > CAM Software > CamWorks > setting 4th axis tilted for clearance
    Jul 2005
    1650
    I need to tilt my 4th axis for clearance so that i can get closer to a flange I have ball end mill work on a cone
    Attachment 404274
    i need to be able to tilt the 4th in Camworks so i have clearance any one able to point me in the right direction
    its almost like having a 5th axis that is locked to a certain degree
    I just need a little guidance
    thanks
    Jan 2014
    32
    Re: setting 4th axis tilted for clearance
    You'll need to draw a plane at the desired angle and create a coordinate system and new operation on that same plane to use.
    Jul 2005
    1650
    I kind of thought that was the way to go..so I am pursing that technique
    thanks for the guidance
    Jan 2014
    32
    If you need some further assistance let me know, I can give you my email if you want to send some files and I can try an guide you in the right direction.
    Jul 2005
    1650
    thank you I got it to program as I think it should will be running a test part soon
    thanks again
  1. Replies: 6
    Last Post: 03-07-2017, 05:28 AM
  2. Controlling Z axis clearance tool paths
    By loddie in forum MadCAM
    Last Post: 06-09-2016, 12:22 PM
  3. Taig Z Axis mod to gain 4 inches of Z axis clearance.
    By Eldon_Joh in forum Taig Mills / Lathes
    Last Post: 01-11-2014, 11:56 AM
  4. Getting Clearance for the 4th Axis
    By GJeff in forum Tormach Personal CNC Mill
    Last Post: 05-02-2013, 09:23 PM
  5. Replies: 2
    Last Post: 03-12-2012, 12:21 AM
