585,708 active members*
3,948 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Fanuc T21i, Wear Offset affects Absolute readout, can I change this?
Results 1 to 9 of 9
    Our Milltronics SL5000 has a Fanuc21i control, after tools are probed and geometry set I then use the Wear offset to adjust dia. of parts, if I get correct sizing at x-0.002 and the program calls for a 5.000 dia. the absolute readout on the screen will show 4.998, I hate this!!! Is there a parameter that will prevent this? I run 4 other CNC lathes in the shop and this is the only one that behaves this way.
    Sep 2005
    272
    Re: Fanuc T21i, Wear Offset affects Absolute readout, can I change this?
    Yes there is parameter for this, I dont have the book in front of me but I have changed it in the past, like you I hate that, I want to see the programed number not the offset, if you got a parameter book, its in there, might be in the crt section
    Thanks positive, I'll look in the book again, but if you can find a parameter number that would be great.
    Sep 2005
    272
    Take a look at parameter # 3104 bit 6 (DAL) should be set to 1 this is for the absolute position, let me know if that is what your looking for.
    Thanks, I won't be running the machine myself for awhile, but I'll check it soon as I can.
    Ok, I finally got to run the machine again, I was wrong about the control, it has a 0i-TD control, I'm used to running a 21i on a Puma 400, anyway I looked up the #3104 parameter and the DAL was set to 1 but it was not in the 6th position. I'm attaching a pic I took.
    Sep 2005
    272
    Do you have a parameter book for the Oi ?
    Jul 2010
    548
    Hi, Chances are if they have a manual, it is in an electronic format. all 4003700 books of the Fanuc control and one can never know where in that "stack" of books to check. :-(
    It takes a Fanuc (guru) to know what parameter is what. OK someone real familiar with FANUC. and which bit to turn on / off.
    If only they ( Fanuc) would make it easy for us "mere mortals"
    But there are a whole lot of Manufactures that use the Fanuc and a lot of them "hide" the parameters.
    Hence the "guru / real familiar guy / gal.
    sportybob
    Sep 2005
    272
    See attachment and look at page 643, this is Fanuc Oi MC but should be the same for what your looking for
  1. Absolute readout & tool length offset
    By leeroy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-29-2019, 11:36 AM
  2. Fanuc OT Wear Offset page locked???
    By grumpy74 in forum Fanuc
    Last Post: 02-21-2015, 08:14 AM
  3. fanuc 10 t tool wear offset parameter
    By karthick in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2014, 11:15 AM
  4. Fanuc O-T Wear Offset Parameter
    By gollame in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-11-2008, 12:40 AM
  5. Wear offset and writing parameters Fanuc
    Last Post: 03-03-2008, 10:15 AM
