585,932 active members*
3,506 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > What is the accuracy of servo position encoders
    Oct 2018
    79
    My understanding is servos use a motor position encoder, but what is the accuracy of that? Is it a patterned optical disk attached to the shaft?
    Nov 2013
    4371
    Re: What is the accuracy of servo position encoders
    the simplest optical encoders are a transparent disc with many dark lines around its perimeter. The presence or absence of a line is detected
    by an optical senor and infra-red LED.
    There are usually three distinct channels, A and B and an index. The A and B channels each have an identical number of lines but one comes on slightly after the other,
    they are said to be in quadrature. The reason is that it means that depending on which signal leads will determine the direction of rotation.
    The Index channel has just one line and 'blinks' just once in every rotation, and is used to synchronize the computer monitoring the A and B channels.
    Once upon a time it was common to have encoders with say 512 or 1024 lines around the periphirary of the disc. Nowadays the entry level norm is 2500 lines.
    As short as ten years ago such an encoder would have been very expensive, not so today.
    With 2500 lines when you combine both A and B channels you get 10,000 (2500 X 4) distinct 'counts' Thus you could have the servo drive to 'a position 5643 counts clockwise
    from the index mark'. Your servo has a potential resolution of 1/10,000th of a turn or 0.036 0 or 2.16 minutes of arc.
    Older servos with fewer lines had correspondingly less resolution. As a practical matter to get within 2 or 3 counts of the perfect position is more achieveable....
    so about 1/10 th of a degree....still very very good. These encoders are called incremental encoders, you need the index signal to give some reference
    position.
    More recent advances are called absolute encoders, they use a Grey Code arrangement of lines and don't need an index mark. They are said to have 16 bit, 17 bit
    and 20 bit resolution. 20 bit resolution will result in 1/1,000,000 th of a turn resolution!!! Even more recent and expensive are 24 bit absolute where the encoder
    counts a whole number of turns and then still has 17 bit resolution within one turn, very exotic!
    If you provide some details about the servos you are looking at we could give you a pretty good estimate of what you might expect in practice.
    The theoretical best is the (number of lines X 4)= counts per revolution. So the angular (best) resolution is 360 /counts. You should get close to this
    unless using electronic gearing within the servo drive.
    Craig
  1. position accuracy when probing
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 10-26-2013, 04:09 PM
  2. Cheap Linear encoders for position feedback
    By TTalma in forum Stepper Motors / Drives
    Last Post: 08-11-2013, 08:36 PM
  3. Parameter defining Encoder Position Accuracy
    By Ramu in forum CNC Machining Centers
    Last Post: 08-01-2010, 12:36 AM
  4. Fanuc 0iMC - Scales vs Encoders. Accuracy.
    By Leha_Blin in forum Fanuc
    Last Post: 10-20-2008, 06:14 PM
  5. Do i need rotary encoders for accuracy?
    By abomination in forum Stepper Motors / Drives
    Last Post: 04-27-2007, 03:02 PM
