585,973 active members*
4,213 visitors online*
Results 1 to 2 of 2
    Sep 2018
    4
    Question Gcode - set axis offset function
    Hi everyone,
    I'm working with SINUMERIK 808D control for sharpening machine,
    when I clean the stone I have to re-offset the Z axis.
    I want to know if there is a G function that let me set a new offset inside the gcode?
    thank alot.
    Gadi
    Sep 2018
    4
    Re: Gcode - set axis offset function
    Hi guys.
    I found something that can help me with this operation, may be helpful for someone.
    https://www.cnccookbook.com/g10-g-co...achining-haas/
    still don't understand the function parameters:
    G291
    G91 G10 L_ H_ P_ R_
    G290
    what L, H, P, R means?
  1. How to handle 4th axis offset , is there a Gcode or ?
    By phucrobusl in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-22-2018, 11:44 PM
  2. Replies: 1
    Last Post: 09-25-2017, 05:53 AM
  3. Gcode to set offset values
    By mioduz in forum Tormach Personal CNC Mill
    Last Post: 05-16-2014, 09:28 PM
  4. drawing from Gcode in wireEdm using offset
    By rattyratty07 in forum Uncategorised CAM Discussion
    Last Post: 09-14-2010, 01:28 PM
  5. Is there a way to feed an offset in manually in Gcode
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2008, 04:30 AM
