585,761 active members*
4,163 visitors online*
    Aug 2005
    205
    Spindle Motor source
    I have a CNC Router Parts Pro kit that I expect to start assembling soon, but need a spindle. I'm looking specifically for a 2.2KW 18000 RPM spindle with an ER25 collet to be used with collet extensions (I need the additional reach). This is for a hobby machine (so on a budget), but will get used as a semi-production machine. This is one that I'm looking at;
    https://www.ebay.com/itm/201631137259
    Are there manufacturers that I should avoid? Any observations/advice are welcome and appreciated.
    Marv
    Re: Spindle Motor source
    Never seen one in person, but the one in your link appears to be of higher quality than most of the others, which tend to be a bit cheaper. If the cost isn't an issue, I'd buy that one. I've bought from that seller before, too.
    Aug 2005
    205
    Thanks Gerry. Thats the kind of endorsement I was looking for.
    Again, I've never used one of those, so if it only lasts a week, it's not my fault.
    But If (when?) my cheap round spindles die, I'll probably be getting one of those myself.
    Aug 2005
    205
    There are no 100% guarantees in life. Only promises.
    I'll take my chances on the one I've picked. If it craps out early, I'll let everyone know. Thanks again.
  1. Spindle motor drive gear source
    By GITRDUN in forum Haas Mills
    Last Post: 01-30-2018, 03:19 AM
  2. DC Servo brushed motor source?
    By j3dprints in forum Servo Motors / Drives
    Last Post: 12-28-2017, 12:15 PM
  3. Source for Stepper Motor
    By ecope in forum Taig Mills / Lathes
    Last Post: 09-06-2011, 08:53 AM
  4. Spindle motor encoder source?
    By Ranchero50 in forum Bridgeport / Hardinge Mills
    Last Post: 04-28-2008, 03:42 PM
  5. Possible motor driver source
    By Grue in forum CNC Machine Related Electronics
    Last Post: 04-28-2004, 11:00 PM
