585,951 active members*
3,766 visitors online*
Results 1 to 6 of 6
    Oct 2018
    Exclamation Mach3 G-Code-Ripper not working
    I have 4-axis 6090 CNC from china,
    i am using "G-Code-Ripper" to work with uneven surface copper pcb.
    but when i run the file.ngc file in mach3 the output in the file gives similar values for each axis,
    though while running the probing it shows proper Z values on Mach3 interface.
    the output file looks like this
    54.97500,21.67500,-0.03750
    Please help me find out the problem.
    Thank You.
    Dec 2016
    Re: Mach3 G-Code-Ripper not working
    Hey, did you ever receive a fix for this. I have a similar issue if the board is very closely level. If it's a lot out of sync then the output file seems to work,
    Jun 2018
    362
    Try lowering the accuracy values in General Settings.
    Quote Originally Posted by he1957 View Post
    I have the same problem, were you able to solve it?
    Nov 2017
    10
    did you ever receive a fix for this?
    Dec 2010
    226
    Quote Originally Posted by madmac4u View Post
    Thank You.
    This is a problem with MACH3 and/or the controller board you are using. Other people have reported problems like this. At least one fixed it by upgrading the firmware on the controller.
    I don't use MACH so I don't know more than that.
    Scorch
    www.scorchworks.com
  1. G-Code Ripper - Scale, Rotate and Split G-code
    By scorch in forum OpenSource Software
    Last Post: 08-26-2020, 03:28 PM
  2. Replies: 4
    Last Post: 03-21-2018, 10:02 PM
  3. Slotting with a ripper
    By jonnoCT in forum CNC Tooling
    Last Post: 05-04-2016, 07:27 PM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. Ripper Mate!
    By rocket67 in forum Excitech routers
    Last Post: 07-30-2008, 06:41 PM
