584,842 active members*
4,614 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Dual motor gantry homing?
    Hello,
    First off, I've been using planet cnc with mk3/4 on two machines for 2+ years and it works really well. Compared it with a few other controllers in real semi-industrial applications and it's significantly faster/smoother.
    Which is why I want to use it on my new builds (a few machines actually), large routers with two motors rack&pinion driving a wide and rather heavy duty gantry. For that I would absolutely need to be able to home both sides of the gantry to maintain squareness, automatically.
    Connecting the two motors via belt is simply not an option, nor is it a real solution in this case.
    I've searched the forums and the manual and seen old posts about that not being possible with Planet cnc, despite repeated requests. I've seen some users that hacked somewhat of a solution, but making my own electronic boards and such is something I really don't have the time to fiddle with.
    Is this something that's possible to implement without making my own electronic circuits? or perhaps already been resolved?
    Cheers
    Mar 2017
    1295
    Re: Dual motor gantry homing?
    In TNG it is possible to create homing script that does this. I don't have script here right now but if you are not in a hurry then wait for tutorial on this topic.
    Awesome, glad to hear that.
    Yes a tutorial will be greatly appreciated! Guess it's going to be time to take the plunge and make the move to TNG.
    Cheers!
    Thank you. Yes that suffices as a workaround, although not the most elegant solution.
    Would be much better if we could run a custom homing script or a custom 'squaring' button without closing/changing profiles, and eliminate the possibility of whoever is running the machine forgetting to switch back to the regular working profile.
    I tend to look at homing before a job as good practice, making sure that everything is where it's supposed to be. with this method it can get kinda cumbersome.
    REALLY happy with TNG btw, been working a treat on my smaller machine save a couple small issues I found:
    1.'start from line' seems to change operating into exact stop mode? decelerating and accelerating for each line segment.
    2. on screen jog buttons cause jerky first movement.
    perhaps these two issues relate to the same thing?
    Mar 2017
    1295
    Start from selected line has been discussed in separate topic.: https://www.cnczone.com/forums/plane...74780-cnc.html
    Regarding jerky jog movement:
    https://planet-cnc.com/planetcnc-tng...ce-guidelines/
    Please perform steps in this article, specially USB HUB connection of controller with PC.
    Best regards, Team PlanetCNC
    Mar 2017
    1295
    Next TNG version will be awesome. I'm working on it right now and I'm very excited. But there is a lot more work to do.
    May 2008
    266
    Quote Originally Posted by PlanetCNC View Post
    Can't wait. I'm very pleased with TNG, it's proving to be reliable and smoooooth!
    When is G76 (screwcutting) going to be up & running again?
    Martin.
    Aug 2011
    998
    Any teaser? What are the planned changes?
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Apr 2012
    91
    Yes a bit of a heads up, would be encouraging for loyal followers?
    Made the move to TNG a couple weeks ago on my smaller machine and so far really impressed! runs smoother and quieter, and the ability to customize the ui buttons/tabs is great.
    Now just need to sort out the dual motor homing so I can get on with the larger routers..
    So any chance of that tutorial or some help with a custom homing script?
    Cheers!
    Mar 2017
    1295
    Very soon. It should be by the end of this week.
    Alright great! waiting impatiently
    Apr 2012
    91
    Hey guys! Long way past the end of that week?? How about a timing update.
    Any progress with this?
    Mar 2017
    1295
    Please follow this link for tutorial on gantry squaring:
    https://planet-cnc.com/wp-content/up...y-Squaring.pdf
    If you will have any troubles or doubts using this tutorial please contact us and we will help if you get stuck.
    We will also be very happy of any feedback. This way we will be able to improve this tutorial and make it more efficient and user friendly.
    Mar 2017
    1295
    Any feedback?
    Nov 2015
    257
    Work this whit latest version oder TNGv2 ?
    Feb 2019
    76
    Can build a simple circuit on two chips CD4001BM, and not use the fourth axis.
    True, I did not check, but it should work.
    Mar 2017
    1295
    This is for old TNG.
    TNGv2 has gantry squaring script built in.
    Nov 2015
    257
    Thanks, that's what I thought.
    Now it is so that I can not adjust the gantry squaring.
    There are various error messages.
    I set everything up as explained in the PDF. I just didn't do the script.
Page 1 of 2 12
  1. Dual Drive Homing and Squaring Script.
    By Greg_Gurden in forum Machines running Mach Software
    Last Post: 05-16-2020, 03:10 PM
  2. Replies: 0
    Last Post: 07-02-2016, 10:28 PM
  3. A dual gantry machine
    By Black Forest in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-21-2015, 01:50 AM
  4. More dual axis homing issues
    By eforer in forum SmoothStepper Motion Control
    Last Post: 11-28-2013, 05:19 AM
  5. Dual motor gantry and Mach3 features that don't...
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-12-2012, 10:03 PM
