585,760 active members*
3,844 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > 40mm finnish birch plywood CNC-router
Page 3 of 3 123
Results 41 to 58 of 58
  1. #41
    Re: 40mm finnish birch plywood CNC-router
    I'd recommend the CNC Drive controllers. I have both an AXBB-E and a UC300ETH.
  2. #42
    Sep 2005
    1740
    When you don't bother to list your location we assume your USA based. But cheap is cheap everywhere.
    Gecko is US based.
  3. #43
    Btw, Gecko makes drives, not controllers.
  4. #44
    Feb 2019
    91
    im staying near china even postage took almost 4 usd only but i still buy us product since i know how problematic is china board if you know any taiwan brand should choose that
  5. #45
    15362
    Quote Originally Posted by hautamak View Post
    Yes, I have learned from that. If only...
    But yeah stepper motors works fine, only inputs are not working. Maybe I'll try something different plugin for that card.
    would this controller be good if I can't get that crappy one to run?
    https://www.ebay.com/itm/NVEM-6-Axis...wAAOSwtVxaJhwK
    There are a lot that are using this Ethernet Breakout Board
    With your other Breakout Board have you added the 24v power supply it won't work without it
    Mactec54
  6. #46
    Sep 2005
    1740
    Quote Originally Posted by teamloks1 View Post
    Gecko does make a controller but its a all in one.
    https://www.geckodrive.com/featured-products.html G540 4-AXIS DIGITAL STEP DRIVE
    $269.00 not sure if this would work for you or not. My wife has relatives in Sweden we get packages from them time to time. Sure its not $3 shipping from China that takes 4 weeks.
    Frankly I would wait for a recommendation from someone who has actually successfully used one BoB with either Ethernet or USB on here.
  7. #47
    Aug 2018
    621
    Check out Centroid Acorn, they ship international and have great forum support. You can even buy one from Amazon it's 299 and the pro software is 139. Very easy to use and easy to wire up and like I said a bunch of helpful guys on the forum to get you up and running.
    Dan
  8. #48
    Jan 2008
    1529
    G540 is not a controller.
    It's a parallel port and 4 stepper drivers in a single package.
    The controller is the bit that actually determines the movement of the machine. For many that is Mach3 or LinuxCNC (PC software based).
  9. #49
    Sep 2005
    1740
    Quote Originally Posted by pippin88 View Post
    The Gecko G540 is a controller when connected to a parallel port. Its as much a controller as a BoB is, both need compatible software to run.
    Our first multi-axis drive, the G540 is our most popular end-user focused product. Capable of driving four independent motors with its discrete internal motor controls at up to 50VDC and 3.5A per axis, it can move motors ranging from small NEMA 17s to large NEMA 34s. The motherboard has an integrated DB25 connector for connecting directly to a computer via parallel port or a third party motion controller. Motor connections are made through DB9 plugs, which are included with the drive, and current can be set differently on each axis via a current set resistor.
  10. #50
    15362
    Quote Originally Posted by wmgeorge View Post
    Not at all it is a drive package that only controls the motors no CPU on board
    The above Breakout Boards have a CPU that controls the drives very big difference
    Mactec54
  11. #51
    Sep 2005
    1740
    You are correct. Seems the Gecko is over priced for what it is!!
  12. #52
    You can buy American, or buy Chinese. Geckos are made in the USA, and subsequently cost much more than Chinese drives.
  13. #53
    Jan 2008
    1529
    No, the G540 is not a controller. Breakout boards are not motion controllers.
    The computer software is the controller.
  14. #54
    15362
    No quite correct a Breakout Board the has a CPU is in control of the machine, the computer is basically redundant at that point, and is only sending the instructions G-code to the onboard CPU, the Breakout Boards that where posted have onboard CPU and are what control the machine
    Mactec54
  15. #55
    Oct 2018
    47
    Hello,
    Little update for this one:
    I bought uc400eth board and mx4660 with it. also going from 24v to 48v. Spindle is going to be 2,2kw chinese air cooled square. VFD is Yaskawa V1000.
    So I'm also rebuildin z-axis as it is weakest part in my design. I'm going with 20mm aluminium plate. does this design looks sturdy? (HGR 20 rails and 1204 screw for z and 1610 for x.)
  16. #56
    Oct 2018
    47
    And forgot to mention, but I'm mainly cutting wood and little bit aluminium. Gantry is 70mm thick plywood torsion box made with 15mm ply. I think it is strong enough.
  17. #57
    Smile Re: 40mm finnish birch plywood CNC-router
    I would assume so, thickness helps. But more important for twist/torsion is the effective cross sectional area and internal construction.
    It's not pretty but in my design (18mm BB 11 ply) the gantry is actually two torsion sections. Each x-section having an equal height and width ratio.
    https://photos.app.goo.gl/8Nz3NREoAEcawz27A
    Far exceeds the needs for wood routing. Haven't got the nerve to try aluminum yet.
  18. #58
    Feb 2006
    174
    Attachment 456802
    Next step would be to remove all the plywood :-) The triangle of the gantry side, that is hanging in free air, won't do you any good, so you can take it off, if you want to.
    Lars
Page 3 of 3 123
  1. Possible to cut 3.5mm birch plywood using 40w CO2 laser?
    By slow_rider in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-27-2015, 01:57 PM
  2. (I'm new) A little Help please. 18mm finished birch plywood
    By Lucilleln in forum WoodWorking Topics
    Last Post: 06-05-2013, 01:24 AM
  3. Birch Plywood Cutting Stratagies
    By gavztheouch in forum WoodWorking Topics
    Last Post: 04-18-2012, 06:50 AM
  4. MDF of Birch Plywood
    By thegimpster in forum DIY CNC Router Table Machines
    Last Post: 01-18-2008, 10:38 PM
  5. euro birch plywood?
    By pixbroker in forum DIY CNC Router Table Machines
    Last Post: 11-30-2005, 03:51 AM
