585,717 active members*
4,051 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Feb 2015
    15
    Re: Yet another 3 axis CNC Router Design/Build
    To cut down on the number of machined components, the thought is to use a table structure that is known to have a relatively good straightness tolerance ie extruded Al, and skin it with a material that is known to have a uniform thickness tolerance to create a planer surface for the rails to fasten to. A steel structure would require machining for flatness or an epoxy pour. I do not have economical access to machine long parts.
    Perhaps this isn’t the best approach, but it seams to be the best given the processes readily available to me.
    That being said, I would prefer to build the table out of steel...
  2. #22
    Feb 2015
    15
    Project update.
    Welded base
    Laser cut sheet metal
    80/20 machined
    table assembly
  3. #23
    Feb 2015
    15
    FYI, by no means do I consider myself to be a welder.
  4. #24
    Feb 2015
    15
    So I am getting ready to install the Y-axis Chinese ball screw under the table ( I am calling my Y-axis the long axis that drives the gantry). I am inspecting screw straightness/run-out prior to install. The screw is a 2525 x 1500mm long ball screw, and will be mounted with a fixed/supported bearing system. I placed the screw's machined ends on V-blocks and measured .0012" of TIR on the drive side of the screw (coupling shaft portion), and .0022" of TIR in the center of the screw. Looking at the specs for a THK screw of this size, they are holding .00078" of TIR on the drive side for a C7 screw. Now I do not expect a cheap Chinese screw to be comparable to a THK screw, but was wondering how many RPM's I might be able to achieve without the machine shaking itself apart? Perhaps the stepper motor RPM's will be more of a limiting factor than any ball screw whip concerns...
    My gut tells me that .0012” runout is more than adequate for a DIY CNC router.
    Ultimately, I am looking for a stable robust machine. Not trying to set any land speed records.
    This is all very new to me, so any insight that others might have would be greatly appreciated.
  5. #25
    Feb 2015
    15
    Update
    Ballscrew installed
    Side plates and guide rails installed
    Painted side plates
    Installed 5/8" thick fixture plate with tapped holes
Page 2 of 2 12
  1. Design and Build own 3 axis CNC router
    By CdRsKuLL in forum DIY CNC Router Table Machines
    Last Post: 03-02-2014, 09:00 PM
  2. 4x4 cnc router build, nit pick my design!
    By jimmyjames1981 in forum DIY CNC Router Table Machines
    Last Post: 10-22-2012, 10:36 PM
  3. 8020 CNC Router Design-Build
    By blatterjr in forum CNC Wood Router Project Log
    Last Post: 08-15-2012, 02:46 PM
  4. Design and build of a metal structure 3 axis CNC router.
    By kostix777 in forum DIY CNC Router Table Machines
    Last Post: 08-16-2011, 06:20 PM
  5. Can I design and build a CNC Router!?
    By morgandhunter in forum DIY CNC Router Table Machines
    Last Post: 10-13-2009, 08:49 PM
