585,748 active members*
3,443 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Q on CC 120M post for Alphacam
    Oct 2018
    Hello all,
    I am wondering if my post can be changed slightly to accomplish the following;-
    The spindles do not stop when the cutter is finished, I have to press a button on the machine to manually stop the spindles when the program is finished, is it possible to make the spindles stop when the machine is finished with the tool?
    I would like to be able to enter an offset for Z, at the moment I have to get the calculator out and enter the tool lengths into the machine depending on material thickness... for every cutter.
    The post works fine, these are just minor annoyances, but I would appreciate any help.
    If it is of any relevance- I am cutting sheet material, plastic and MDF.
    See post attached.
    Thank you.
    Apr 2015
    327
    Re: Q on CC 120M post for Alphacam
    "The spindles do not stop when the cutter is finished, I have to press a button on the machine to manually stop the spindles when the program is finished, is it possible to make the spindles stop when the machine is finished with the tool?"
    This caused M0 on a end of program - machine is in a "stop mode" and you have to finish program by next press machine button
    "I would like to be able to enter an offset for Z, at the moment I have to get the calculator out and enter the tool lengths into the machine depending on material thickness... for every cutter.
    Do not understand your request correctly. You mean some Z offset like G92 Z? .... or do you have some example?
    M.
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Oct 2018
    I'm not sure it is because of the M0. On the machine there is a button called "Spindle stop", it is specifically for stopping the spindle, I am not pressing the cycle button if that is what you thought. And the machine goes home without my intervention.
    I have worked with a different post that asked me for "Z offset" when I output the program in alphacam, that is what I would like. The offset would be whatever the sheet material thickness is. At the moment I cannot put an offset in and I have to change the cutter lengths in the machine instead.
    Thanks.
    Jun 2009
    5
    Hello Chris,
    a bit rusty on this but if you go into alphaedit you can edit the post. Copy it first before you change anything and play with the copy. look for the "trailing lines or end of programme" and add the M code to stop heads. other option is to manualy put it at end of programme in machine.
    Stuart
  1. Need help with Alphacam post
    By hd4684hg in forum Alphacam
    Last Post: 04-23-2017, 08:47 PM
  2. BOSCH 120M LSV2 Board not ready.
    By MikeREvans in forum Uncategorised MetalWorking Machines
    Last Post: 09-07-2016, 08:45 AM
  3. AlphaCAM post
    By KLarson in forum Shopsabre
    Last Post: 08-09-2016, 04:32 PM
