585,729 active members*
4,900 visitors online*
Results 1 to 8 of 8
    Jun 2015
    29
    THC G-code problem
    Hi everyone, I have a problem with THC G-code. When I uploaded the G-code in Planet TNG software and started to run it, the program just only ran a little bit and stopped at N51 line. I don't know why. Below is my G-code for referent. Could somebody help? Thanks a lot.
    Attached Files Attached Files
    Mar 2017
    1304
    Re: THC G-code problem
    M54 enabled THC. Program is waiting for ARC OK signal.
    Jun 2015
    29
    Quote Originally Posted by PlanetCNC View Post
    I got it. Thanks you very much.
    Jun 2015
    29
    Hi PlanetCNC,
    I have already connected the THC (Proma SD) with plasma source (Hypertherm 45XP) dirrecty as your guide on the blog but the machine just only ran over the THC code line a little bit as the picture. First, the torch contacted with the tube face then the plasma arc fired and stopped even when I have already tested THC operation well before. It did'nt work like as your clip ( The torch and the steel surface contact together then the torch move up and fire the plasma arc).Have I missed something in the way to set up on the software or wiring ? Could you please to show me?.
    https://planet-cnc.com/thc-torch-hei...planetcnc-tng/
    https://planet-cnc.com/how-to-connec...lasma-cutters/
    Mar 2017
    1304
    Do you have a OK arc pin configured in settings? If yes then software waits for un-existing ARC OK signal.
    Do you use 10.30 version of TNG?
    Jun 2015
    29
    Thanks for your replies,
    I have already checked and recongnized that a OK arc pin hadn't been connected, but I did'nt found the wiring diagram for a OK arc output with Cpmpact THC SD (proma) in your guide. The THC is seem to be not have a OK arc signal output. Should I need to configurate a output on the MK3 BOB like the picture to connect with a OK arc pin of the hypertherm source?. Could you please to show me?.
    Attached Thumbnails Attached Thumbnails Compact THC SD wiring.PNG   images.png   Screen-Default-1-520x500.png
    May 2015
    686
    The 45XP has the ArcOK signal in its cnc connector. It has nothing to do with the THC.
    Rod Webster
    www.vehiclemods.net.au
    Jun 2015
    29
    Quote Originally Posted by rodw View Post
    Thank you a lot rodw,
    I just need to connect the pin 12 & pin 14 on the hypertherm cpc port to the GDN& OK input pin ( config input pin 3) on the MK3 controller, right? .
    Attached Thumbnails Attached Thumbnails Hypertherm CPC port.PNG   Hypertherm arc OK pin.PNG   MK3 controller arc OK input pin config.PNG
  1. g-code problem
    By accuratesports in forum Dolphin CAD/CAM
    Last Post: 12-12-2013, 01:25 AM
  2. code problem please help
    By fanouxri in forum Okuma
    Last Post: 11-13-2013, 03:24 AM
  3. G Code Problem
    By Dr Bob in forum Uncategorised MetalWorking Machines
    Last Post: 12-03-2009, 08:39 PM
  4. g code problem
    By SIMONSIGNS in forum Uncategorised CAM Discussion
    Last Post: 03-22-2007, 04:46 PM
