585,931 active members*
5,375 visitors online*
    Jan 2012
    43
    engraving beyond size
    Have 708lite controller and lasercut ver 7.68. Having a problem with the controller suddenly showing " engraving beyond size" and stopping the run.Had been doing this some but before the run was started. Now it's doing it intermittently after the run has begun like after 1+2min and then stops.
    I've been able to get it to work by removing most or all of the files stored in the controller and resetting the system from the front panel.
    Any ideas as what may be causing this?
    I seem to remember a second way to reset the controller for a better memory purge but don't remember what the procedure is. Anyone know?
    Sep 2018
    83
    Re: engraving beyond size
    It sounds like your files are overflowing the machine's onboard memory. What sort of files are you running? I'd make a point of purging as much hidden or non-cut data as possible from the files themselves, as well as emptying out the onboard memory ont he laser, too.
    Are you loading files using a USB stick, or are you using a link from your computer? I'm not aware of there being a version 7.68 for the lasercut software range, but I'll have a lok around and see if I can find a copy - I know 5.3 pretty well, but if there's a major difference betwen versions, that probably won't help you.
    Jan 2012
    43
    Thanks for the reply.
    Using draftsight and coraldraw 5x on a desktop computer with windows 7 via usb connection.
    I mostly use DXF files or some BMP
    I am very sure there is a way to purge the memory on the controller other than the RESET button on the front panel. Had a friend tell me the process but i have forgotten how and he passed this last January. He would tell me that the reset did not clear all the garbage out of the memory that would build up over time and then limit the amount of usable memory for the working files.
    It's been awhile now that I used ver 5.3 but as memory serves: the page layout is better, more options to work with the files, better est on work time, cad features somewhat improved, ect.Just look for lasercad 7 on the net. found mine under "banggood" and was able to download the file and manual for free.
    Rick
    GerryG Guest
    Ah, that explains it - lasercad and lasercut are different software packages entirely. I'm afraid I don't know anything about the control systems for the kind of laser you're using - if it was running lasercut, then it'd be a leetro system, which I could help with.
    Sorry.
  1. Problem engraving size.
    By futures in forum Chinese Machines
    Last Post: 09-03-2015, 02:33 PM
  2. Replies: 0
    Last Post: 04-15-2011, 03:45 AM
  3. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum Mach Plasma / Laser
    Last Post: 10-04-2007, 02:49 PM
  4. for engraving pcb which is a good thread size for the lead screw?
    By NickLatech in forum DIY CNC Router Table Machines
    Last Post: 01-18-2005, 03:37 AM
