585,974 active members*
4,188 visitors online*
Results 1 to 6 of 6
    Dec 2016
    24
    Ballscrew assembly
    I'm trying to assemble supports of 2010 ballscrews. I succeeded one but two of fixed side support (BK15) are very difficult to push. Do you have any recommendations ?
    Re: Ballscrew assembly
    The reason why difficult to install are because the BK support not correct or the machined ball screw end in larger tolerance?
    If just because the tolerance is little bigger,you can try to polish the ball screw by sandpaper in a bit.
    Generally the tolerance will not bigger too much so just need polish a little is OK
    Meanwhile after polished if still in little bigger,you can use a small hammer to hit it carefully.
    Nov 2005
    222
    I would polish or sand the shaft until it is a light press fit. Keep in mind that someday you may want or need to take it apart again. If it is a heavy press fit that will be difficult.
    John
    Jul 2014
    63
    Cold and heat are your friends for tight fits with metals!
    Sent from my SM-G960U using Tapatalk
    Recommend not polish to much,during the working the backlash will became more and more loose,if in heavy press can keep the suitable accuracy for longer working time.
    Dec 2016
    24
    Thanks everyone!
    Finally I attached the ballscrew and gently hit with a hammer the inner race of the bearing to just have enough thread to be able to screw the lock nut and push the bearing in place.
    This worked great but I think cold and heat is a better method.
  1. G0602 ballscrew/ballnut assembly
    By bpratl in forum For Sale Only
    Last Post: 09-22-2015, 07:42 PM
  2. EZPath Z-axis Ballscrew Assembly Removal
    By md63825 in forum Bridgeport / Romi Lathes
    Last Post: 02-23-2012, 08:36 PM
  3. Re-assembly of X-2???????
    By Smitty911 in forum Benchtop Machines
    Last Post: 07-13-2007, 11:16 PM
  4. Replies: 10
    Last Post: 01-16-2007, 06:27 PM
