Re: Mach3 tool info not showing
You have to output in code for your tool changes.
T(x) M6 G43 H(x)
Yes, I think its stupid, but that's the way it is. I considered trying to modify my tool change macro to do that, but I found it was easier to modify my CAM post processor to do it. For convenience you may want to setup your tool change macro to move to safe Z height for the tool change. If you move in X&Y for the tool change you may want to also want to save the current X&Y before the movement, and return to it at the end of the macro. Many CAM programs do not output all coordinates for the first move if the machine was at that that coordinate at the end of the last operation. Saving coordinates and returning to them prevents that from being an issue.
I would suggest when modifying a post processor you save it under a new name so you can always refer back to the original if something doesn't work the way you thought it should.
Bob La Londe
http://www.YumaBassMan.com
