Re: b axis -overflow mx45vae u100m
hi, i can't help you fix your problem, but i can tell that such things may happen if a rotary axis is being rotated too much among a single sense
i encountered similiar stuff with the C axis on a lathe
somehow you need to reset the encoder, and also you need to check what is causing this
try rotating it in manual, with the ILK button pressed
i don't know for your machine, but on some models is an over-travel-release-switch
in the future, write down the value of the encoder for 0 position, and check later the actual position, so to see if it remains unchanged, or if it changes with 360*
hmm ... try editing the encoder origin ? it may be also linked to other parameters ... about editing the parameters, i would suggest contacting your service suplier; or just write down the actual values, and go experiment : try making the actual position to be equal with encoder origin / kindly
