585,605 active members*
3,294 visitors online*
Page 2 of 6 1234
Results 21 to 40 of 119
  1. #21
    Jdubya Guest
    Re: 60" x 40" new build
    Quote Originally Posted by skrubol View Post
    If that's full-stepping and my math is right, looks like that graph ends around 800 RPM. My guess is you've got plenty of torque, especially if you're going to have 2 of those. At 600 RPM, it's around 3Nm of torque, so around 3700N of linear force before drag, figure around 3kN per screw with drag. If you've got 2 steppers/screws, that's 6kN force, so.. plenty for a lightweight router.
    I am going to trust you on the math as I can not do it. I am a dumb welder and not a very good one at that. lol. It sounds like I should be ok though, thanks for that. . Thinking about trying to wire it all up on the bench for testing the motors in the morning (not real confident on the configuration) . I can copy what others do on youtube and it works for them so i should be able to make them spin.
  2. #22
    Oct 2018
    98
    Anyone familiar with this ebay 6 axis controller? I searched and I see nothing on it here? I attached the .pdf manual but I am a newb. It looks interesting compared to the no name breakout board that my kit came with?
    edit: It actually says: "No best but better" lol sold...
    This is probably not the right place for this.
  3. #23
    It's half stepping. Not sure how fast the torque falls off after the chart, but 2500pps is 375rpm. With 1605 ballscrews, that's only 75ipm.Painfully slow for a machine this size.
  4. #24
    I would avoid all chinese Mach3 controllers. They all have various issues.
  5. #25
    Oct 2018
    98
    Thanks Ger21, i ordered the eithernet smooth stepper.
    "Painfully slow" hmmm not good.
  6. #26
    Oct 2018
    98
    Open to any suggestions? 20mm screws and smaller faster motors? I had previously order the nema 23 425oz motor kit but was told they were too small for bigger machines? Not sure what direction to go now?
  7. #27
    5mm pitch screws are a really bad choice for a router. I'd recommend 2010 screws. With the motors you have, 2020 or 2525 would be a better choice.
    The 425oz motors probably would be under powered, and would also be a bad choice. They also typically have high inductance and suffer from poor performance at higher speeds, or a lack of high speed performance.
    I would think that 640 oz motors would be as big as you need with 10mm pitch screws. But it's important to get very low inductance motors, and run them at a high voltage (60-70V).
  8. #28
    Oct 2018
    98
    Thank you Sir!
    Edit: im looking at 640oz motors. The inductance says 4 and my power supply and drivers seem to match fine . 4 is better than 22 i assume. .
  9. #29
    Oct 2018
    98
    So before i purchase, can someone confirm that these motors
    https://www.ebay.com/itm/NEMA-34-5-5...EAAOSwFc5Xv-Zu
    are a good choice, and that they will work properly with my 350W, 60VDC, 5.9A Power supply and DM860A 7.8A/80VDC/256 Microstep drivers?
    Thanks.
    Edit, for link
  10. #30
    Apr 2004
    5731
    The power supply seems weak for those motors. They want 5.5 amps each, but your PS only supplies 5.9 total. You need to give it enough current so at least two motors (3 is safer, since you might be running Z as well) can run at full power at the same time, which would take 11 amps, or 16.5 for 3. And if you're using two motors to drive the X axis, then you'd want to supply 22 amps (although you could probably get away with a little less). They only need 64 volts at max, so you're OK there, and the drives aren't a problem. I'd say look for a supply rated at 1000 watts or more.
    Andrew Werby
    Website
  11. #31
  12. #32
    Oct 2018
    98
    Quote Originally Posted by awerby View Post
    I have a seperate power supply and driver for every motor.
  13. #33
    Oct 2018
    98
    Its a good price. I am kinda lost on the 8 wire unipolar, bipolar serial and bipolar parallel amps bit as it relates to my on hand power supplies.?
    Im in over my head here.
  14. #34
    You want to wire them bipolar parallel.
  15. #35
    Oct 2018
    98
    Ok, thanks and then my power supplies on hand, would also need to be upgraded to match as i understand it.
  16. #36
    No, you're power supplies are fine.
  17. #37
    Oct 2018
    98
    Great! Again, thank you for your help. 2010 Screws are ordered. Will order these tonight. Back on track. Soon ill have enough extra parts to build a second machine.
  18. #38
    Oct 2018
    98
    Now im thinking about moving the screws to the outside of the ibeam again, so i can connect my table to the side rails better.
    Easy enough i guess. These new 2010 screws may not fit where the 1605's are currently located. Its pretty tight now. Well see.
  19. #39
    Oct 2018
    98
    I have an ESS wiring question about this diagram from automation technology. It shows 5v going into the ESS and then out of the terminal board and supplying all 4 drivers with 5v. Is that correct? I have a clean 5v 5a power supply, i was going to run 5) 1 amp fuses to the ESS and the 4 drivers.
    8070D driver Box Wiring (4821)
    https://www.automationtechnologiesin...oad.php?id=365
  20. #40
    Oct 2018
    98
    So... I guess that was a dumb question... I will stick to the diagram. Lol. . I got my power supplies, ESS, drivers mounted in a pc tower. Just about ready to wire it up.
    My bk15's and bf15's came in, they are larger than the bf/bk12's of course, so i will be moving them to the outside rail afterall.
    The nema 34 640's are in, just waiting on the new 2010 screws now.
Page 2 of 6 1234
  1. Mark's EPOXY Granite 18"x20"x20" (700mmx780mmx780mm) vertical mill build
    By gt40 in forum Vertical Mill, Lathe Project Log
    Last Post: 01-19-2019, 09:26 PM
  2. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  3. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
