585,888 active members*
4,083 visitors online*
    Apr 2017
    41
    cuts not precise
    very frustrating issue. some of my cuts are not the exact measurements i need them to be. for example - if i cut several pieces that are 8x10, some are 1/32-1/16 longer than what's in the file. i ran several tests and i *believe* i have narrowed down the issues, the cuts going horizontal to the machine are a little longer than when traveling vertical. not sure what's up here! any help would be appreciated, thanks!
    next wave shark hd3 ext
    cut2d pro
    i cut mainly acrylic but this issue happens on different thickness with different size bits, so i don't believe those are factors.
    Apr 2004
    5737
    Re: cuts not precise
    That could be due to backlash. Backlash is the error you get when a screw changes direction. Since there's a little gap between where the screw threads bear on one side of the nut's threads and the other, the motor will turn a little before the threads engage. Expensive machines have ball screws using double or preloaded nuts that have little or no backlash; cheaper machines have to deal with it. CNC control programs have ways to compensate for it, but you need to measure it accurately first, before telling the program to add a certain number of steps when the screws change direction.
    It could also be that your steps-per-unit settings are a little off - that would be the first thing to check, before dealing with backlash.
    Andrew Werby
    Website
    Apr 2017
    41
    Quote Originally Posted by awerby View Post
    thanks for the info. i researched backlash and that led to me checking all the bolts. some where loose. although i’m not quite sure where the t-nuts are. i’ll also look into that setting. thanks!
  1. New Tube but only cuts for 30second then laser cuts out
    By JBxrayman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2016, 05:57 PM
  2. Good Cuts, Bad Cuts
    By JSR03 in forum Fanuc
    Last Post: 03-30-2016, 09:37 PM
  3. Does tool life vary with interrupted cuts to continuous cuts
    By acejunker in forum MetalWork Discussion
    Last Post: 08-08-2014, 02:34 AM
  4. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  5. which cnc package cuts 2D parts with least extraneous cuts?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2007, 12:29 AM
