585,991 active members*
4,585 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 4 axis tb6560 with mach3 and stepper motors 23
Page 1 of 2 12
Results 1 to 20 of 21
    Oct 2018
    11
    Unhappy 4 axis tb6560 with mach3 and stepper motors 23
    hi , i tried to build my first cnc machine , i am using tb6560 4 axis ( blue board ) with mach3 and stepper motors nema 23 .. the problems is that i burned ic twice i don't know why!! , i applied 23 volt on board, if pins configuration are wrong this make ic burn ?
    also how can i know the motors are locked up ?
    anyone help pls
    Apr 2004
    5737
    Re: 4 axis tb6560 with mach3 and stepper motors 23
    People often have problems with these ultra-cheap driver boards. You can find many more sad stories about them on this site. There's also a (very long) thread started by someone who managed to fix his board - you might find it interesting: https://www.cnczone.com/forums/gener...-software.html
    But the easiest solution would be to spend more money and buy better drivers and a breakout board that actually works.
    Andrew Werby
    Website
    Oct 2018
    11
    okay agree with u but i think the problem is not in board it is in software , if someone know the correct pins configuration and how to check the connection between pc , board and motors it will be good because when i turn on the board with motors and pc, only the leds in board for power are turned on ( two) but other leds for motors are turned off
    Mar 2007
    2083
    which 4 axis tb6560 board do you have ?
    a link to the advert and the manual for your board will help
    different versions of the board may not have assigned the same functions to the printer port pins
    errors with the pin assignments in software will only stop the board working as expected
    and will not damage the board
    what stepper motors do you have ?
    some kits have motors with too much inductance to use with a 24V power supply
    the maximum operating voltage for the tb6560 IC is 34V
    some kits are supplied with a 36V power supply that makes it very likely the board will fail after a short time
    If your using the correct supply voltage
    the only way to damage the board is either incorrectly wiring the motor or disconnecting / connecting the motor with the power on
    the LED's you made ref to in post 3 indicate the logic level on the step inputs
    if the step pin is normally at a logic 0 the LED will be off
    as you step the motor the LED will be on when the step pin is at a logic 1 (+5V)
    at slow speeds you may not see the LED is on
    the LED will be brighter as the step rate is increased
    (alternatively if you set the step pin to active LOW instead of active HIGH the LED will be on and dim as you twep the mptor )
    John
    Oct 2018
    11
    i am using tb6560 4 axis (blue board) and stepper motors nema23 with power supply 24V-15A , i did the instructions in user manual file but nothing happen, the leds turn on only when i push on x- and turn off when i push x+ (on mach3) without any movement ,i made step motors output active low
    Oct 2018
    11
    this is my setup , i don't know what should i do after this
    Attached Thumbnails Attached Thumbnails IMG_20181028_214531.jpg   IMG_20181028_214541.jpg   IMG_20181028_214550.jpg   IMG_20181028_214748.jpg
    Oct 2018
    11
    what should i check ?
    Mar 2007
    2083
    in post 6 the details are missing
    blue tb6560 4 axis board is not enough detail can you post a photo and / or link to a pdf copy of the manual ?
    some are like the board found in this thread
    newer " blue boards " have a micro controller and switch mode voltage regulators instead of the linear regulators on the original boards
    nema23 only gives the physical size of the motor
    if you can post the part number or electrical specification - coil resistance , voltage , inductance
    john
    PS
    old version of 4 axis board
Name:	old blue board.jpg
    Attachment 404772 tb6560 User Manual
    new version
Name:	new version of 4 axis board b.jpg
    Mar 2015
    409
    Quote Originally Posted by mahmoudelomda View Post
    • Can you turn the motor by hand when you are not jogging?
    • Is it harder to turn the motor by hand when you are jogging?
    • Disconnect the motor, turn the motor by hand, short 2 wires, turn the motor by hand, if it is harder to turn, you have found a pair of wires, if not, try one of the other two wires until you found a pair. Connect the pair of wires found to A+ and A- and the other two wires to B+ and B-.
    • Set the step pulse delay in Mach to 100 ms. Some boards are designed totally wrong and need this kind of long delays to work. I have bought one of these from Wantai
    What ic did you burn?
    Oct 2018
    11
    Quote Originally Posted by hfjbuis View Post
    * one motor only i cannot turn while jogging
    * i checked the coil by voltmeter and knew two A wires and B wires
    A+(black) A-(green) B+(red) B-(blue)
    * where can i change step pulse delay ?
    * what are 4 leds inductors in the board refer to ?
    Oct 2018
    11
    Quote Originally Posted by john-100 View Post
    john
    PS
    new version
    i use this board, i think it's old version ( https://www.ebay.com/itm/CNC-TB6560-...0eea:rk:1:pf:0 )
    and( Stepper Motor: Bipolar, 200 Steps/Rev, 57×56mm, 2.5V, 2.8 A/Phase ) 4 wires
    your links are invalid
    Mar 2007
    2083
    not sure what happend but this is a copy of the link I thought I added to post 8
    John
    PS
    on close inspection the 4 axis manual I posted in post 8 only shows the motor connections for a 3 axis board !!!!
    from this manual for another board
    Attachment 404896
    this is how I would connect your motors
Name:	4 axis board.jpg
    Oct 2018
    11
    John
    PS
    Attachment 404896
    so do u know * what are 4 leds inductors in the board refer to ?
    and those output signals are there necessary to run motors? and what configuration for them ?
    Mar 2007
    2083
    as I made referance in post 4
    the LEDs show the activity of the axis step input
    taken from
    this shows what I mean
    Attachment 404952
    John
    Mar 2015
    409
    Check this video on tuning stepper drivers. In the same setup screen you can set the step pulse width
    https://www.youtube.com/watch?v=JzHdGG90TCw
    Oct 2018
    11
    thanks for all of u for your time i appreciate it
    so i set pins configuration motors output , enable, estop , step pulse ...etc
    but motors still donnot move but make a sound !
    i measured volt on motors wire i found between 4 and 6 volt so what should i do ?
    Mar 2007
    2083
    an audible sound from the motors is to be expected
    the TB6560 stepper driver IC controls the motor current by switching the motor current on & off at about 1000 Hz on some boards
    the frequency depends to some extent on the inductance of the motor
    the 4 and 6 volts you measured is unlikely to be correct due to the complex shape of the AC voltage across the motor coils
    once you have the motor data you may find the motor voltage is about 2 to 3V
    most meters your likely to buy average the voltage being measured and are only calibrated to be correct for sinousoidal volatages like the 50 or 60 Hz mains supply
    ( not many are going £500 on a Fluke meter
    https://instrotech.com/fluke-87v.htm...20group%20%231 )
    did you find the part number for the steppermotors ?
    unless you can down load the data sheet for the motors or the instructions for a cnc kit gives you the motor current you need to set the stepper driver to
    you could either set the current too low so the motor torque is too low to move or
    you set it too high and the motor over heats ( more than 70 to 80 C)
    John
    Oct 2018
    11
    John
    Steps per revolution: 200
    Current rating: 2.8 A per coil
    Voltage rating: 2.5 V
    Resistance: 0.9 Ω per coil
    i set dip switches
    75% for current
    25% decay mode
    1/2 microsteps
    Mar 2007
    2083
    75% of 3.5A is close enough to the 2.8A for the motor
    looking at the diagram I added to post 14 and the TB6560 data sheet
    the axis activity LED's should be bright and dim the faster step pulses are sent to the board
    this means the TB6560 step input pin is normally low and goes high (+5V) at the start of the step pulse
    if the enable sent to the board is correct, it should be difficult to manualy turn the motor spindle
    what happens if you unplug the printer cable ?
    I expect the axis activity LED's will be off and the driver will be enabled so it will be difficult to turn the motor spindle
    John
    Oct 2018
    11
    John
    link is invalid
    * leds turn on when i connect power but i can move motors by hand ,the motors locked up only when i push reset button ( motors are active low) and when i measure voltage for one motor one coil give me 2.4 volt but second coil give me 6.3 volt and sound !! but still no movement for motors
    * how can i control output voltage for motors although dip switch current is 75% (2.8 A)
    * this is motor tuning setting in pic
Page 1 of 2 12
