Ebay listing: https://www.ebay.com/itm/173612046203
Please see pictures on my site: andrewbaranwagner.com/2018/10/28/mill-for-sale/
2015 Precision Matthews PM940 CNC mill. Lows hours, well maintained. Approximately 200 hours of machining time on the ways. Spindle bearings and motor have 25 hours of machining time on them. Under power, come see it run before you buy. Also willing to do test cuts for serious buyers. Please contact me with any questions. Specs listed below. This machine has a slightly larger machining volume and spindle power than the Tormach PCNC1100, but otherwise is a fairly similar machine.
Spindle (poly v-belt):
Taper: R8
RPM range: 0-7000
Motor: 3 HP (2.25kW)
Table Dimensions: 40" x 9"
Cutting area:
X: 23"
Y: 14"
Z: 20"
Max feedrate: 100 IPM (steppers motors on all axes).
Required power: 220V, 30A
Machine weight: 1,300 lbs
Includes control computer running Mach3, enclosure with lights (suitable for flood coolant), automatic oiler, flood air/coolant setup (and flood coolant pump), mist coolant, two Shars 440V vises, clamping kits, and parallels.
Delivery/installation available within NJ, eastern PA, and southern NY.
Please note that this item ships freight due to its weight and size, and that rigging may be required to move it from the carrier's vehicle into a structure. Buyer is responsible for freight charges, including cost of palletizing machine.
Also available (but not included):
16 Tormach TTS holders (including 2.5" face mill).
Machinist's toolbox with assorted end mills and drills.
Haimer 3D Sensor.
Edge Technologies touch off gage and spindle tramming tool.
California air tools compressor.
Shop Fox 4x6 bandsaw.
Hydraulic cylinder and pressure intensifier to build power drawbar for single button or automatic tool changing.
Raw stock (aluminum, carbon/stainless steel).
