585,894 active members*
5,043 visitors online*
    Oct 2018
    Romi g10 alarms no manuals
    Hi
    Please need help with a romi g10 lathe with fanuc 21it manuals for fanuc and the machine.
    I have a :2004 hydraulic low pressure
    1002 emergency stop circuit fault
    The hydraulic pump is working but no oil on any hose.
    any help is appreciated
    Nov 2004
    239
    Re: Romi g10 alarms no manuals
    3 phase power? Phases correct? It is possible to get the phase reversed which would run the hydraulic pump backwards and not produce any pressure.
    May 2016
    526
    Hi Jim
    Does the machine have a swarf conveyor or bar-feed as they could be interlocked with an e stop ?
    check the phases on the machine
    Is the white power light on ?
    Quote Originally Posted by Jim1974 View Post
    Hi
