Hello Tom,
I am retrofitting a machine at work, and I can't seem to connect to Kflop. I downloaded the latest Kmotion build and installed it on my laptop, which is running Windows 10 Pro Version 1803. When I installed the software Microsoft visual C++ would not install because I had previous versions installed (basically every year but 2015 if that makes a difference?) Other than that, I am at a loss. The board was purchased a couple of years back and has never been used. It powers up normally (I am supplying power through Kstep J6 and have Kflop J3 removed). If I try powering 5v via Kflop, it still is not recognized. Any help here is appreciated!
Spank
edit: I also just tried connecting to another computer in the shop, and it won't connect either. On that machine I uninstalled all previous instances of MS Visual C++ so that the 2015 version required by kmotion would install...
