... time flies by ....
I got the X axis set up using a 20mm x 5mm pitch ballscrew I'd bought cheap. I attached the ballnut to the carriage as detailed above, and used a modified BK15 support on a new end plate I machined for the left hand side from some 10mm steel plate. This has been ok for a 2D partial CNC, but I need to get the Z Axis conversion done and then I can make some improvements to the X axis adaption to address some of the shortcomings:
- increase X travel from 300mm to closer to 360mm by moving the dovetail shield curtains further out
- support the free end of the ballscrew to allow higher rapid speeds without the possibility of whiplash
- decrease the distance the stepper sticks out on the left side of the machine
- making a new endplate on the right side to tidy things up, currently the hole from the original acme screw bearing is covered by gaffer tape.
I'll attach some photos that I took while converting the X axis. I will do some more design and upload some sketches over the next month to show further changes I want to make on this mill.
