585,585 active members*
3,796 visitors online*
    Feb 2005
    829
    Upgrading a Standard machine to Pro
    So I am trying to sell my Standard CRP4896 you can see here, I want to upgrade to a CNCRouterparts Pro.
    https://www.cnczone.com/forums/cnc-r...21588-cnc.html
    If it doesn't sell I am going to start working on doing an upgrade to linear rail and Pro drive modules.
    I notice while looking thru the PRO assembly directions that is uses 20mm linear rail on the long Y-axis.
    Wouldn't 15MM rail be enough? Or is there something I don't understand that needs the 20mm on the PRO.
    Re: Upgrading a Standard machine to Pro
    My guess is that the15mm are too small to lay over the slot in the extrusion. And they can be tricky to work with, because they use small 4mm bolts.
    The cost to go with 20mm is not very much, and they are much easier to work with. The bearing blocks on 20mm rails are about twice the size of 15mm blocks.
    Feb 2005
    829
    Ger21, I didn't even think of the bolt size. Hiwin EG 15mm rail mounts with M3! Even the hiwin HG mounts with only M4.
    So next question hiwin EG or HG?
  1. Anyone planning on upgrading from a G0704 size machine?
    By ramenftw in forum Benchtop Machines
    Last Post: 03-27-2015, 08:17 AM
  2. Upgrading a K40 moshidraw machine to DSp
    By Scottbgv in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-10-2014, 07:07 AM
  3. non-standard machine
    By robvoss in forum Mach Software (ArtSoft software)
    Last Post: 08-20-2012, 10:57 PM
  4. Metric and Standard on the same machine
    By upnorth in forum Mach Mill
    Last Post: 07-07-2011, 10:44 PM
  5. Upgrading dos machine
    By alan.styer in forum Commercial CNC Wood Routers
    Last Post: 06-12-2011, 02:36 PM
