585,974 active members*
4,245 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Control 810D Siemen cnc Machine VMC how to set offset spindle Orientation position
    Hi Every One
    During tool change spindle is not at basic orientation position the deference is approximately 120 degree
    How can fixed the position or error
    any idea
    Thamks in advance
    Rana Ali
    Jun 2017
    12
    Re: Control 810D Siemen cnc Machine VMC how to set offset spindle Orientation posi
    Go into CNC ISO page, MENU SELECT - STARTUP/SETUP - SET PASSWORD (SUNRISE) - MACHINE DATA - AXIS MACHINE DATA / AXIS MD (select spindle using vertical AXIS + / AXIS - keys), search for 34090(0) and add / subtract offset to figure already in there working on 0 as a minimum, 360 as a maximum), press input then vertical key SET MD ACTIVE. Power down, re reference, check spindle orientation, adjust and repeat until it's right.
  1. Twin cam / 810 Siemen control position issues on wood router HOLZHER
    By wvagas in forum Commercial CNC Wood Routers
    Last Post: 04-17-2017, 12:34 PM
  2. How does a typical CNC machine control X-Y-Z position accurately?
    By SouthPark in forum Linear and Rotary Motion
    Last Post: 11-26-2016, 11:13 PM
  3. TT1800SY Turret position orientation
    By Don18P in forum Daewoo/Doosan
    Last Post: 12-18-2013, 04:44 PM
  4. I CAN PAY FOR! Need postpro for Siemen 810D
    By cncdeckel in forum Post Processors for MC
    Last Post: 07-12-2012, 01:15 AM
  5. Spindle Orientation Position Adjust
    By pinguS in forum Fanuc
    Last Post: 11-16-2006, 05:02 PM
