585,761 active members*
4,129 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Deleting unused and outdated components
    Sep 2017
    I am trying to clean up my folder of custom components that are no longer needed. When I select the version button on bottom right corner, it shows a list of the previous versions. Clicking on Uses shows 'This item does not reference any other designs.' Clicking on Used in shows 'This item is not referenced by any other designs.' Clicking on Drawings shows 'No drawings for this design.' Yet when I try to delete the component, it says 'A version of this design has been referenced by drawings or other designs and cannot be deleted.' So how do I delete this component? Thanks for any help.
    Aug 2016
    185
    Got the same issue...
    Sent from my XT1635-01 using Tapatalk
  1. outdated community college training...
    By jimmyjames1981 in forum Community Club House
    Last Post: 09-04-2012, 02:22 AM
  2. Some advice on outdated to digital and back again.
    By SirHelpAlot in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-07-2012, 01:49 AM
  3. Older Bridgeport with outdated cpu
    By Greg_B in forum Bridgeport / Hardinge Mills
    Last Post: 05-20-2009, 10:20 AM
  4. Need outdated supermax part.
    By Crashmaster in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2009, 09:07 PM
