585,975 active members*
4,658 visitors online*
IndustryArena Forum > CAM Software > MadCAM > No g-code file generated by Madcam in Rhino
    May 2009
    23
    I have encountered a problem that I am unable to resolve.
    I have attached a picture, which shows on the right the window for postprocessing and creating g-code file. No errors there and it says the location and name of the file that was created.
    But the problem is that the file is not there. In the attached picture on the left is "open" window at the folder, where the g-code file should be, but the folder is empty.
    I have tried reinstalling Rhino and Madcam and now I am totally out of ideas.
    I would appreciate any suggestion or poke in the right direction. Thanks in advance!
    Mar 2004
    1661
    Re: No g-code file generated by Madcam in Rhino
    Can you make a test with the default 3 axis LinuxCNC post processor?
    I have a feeling that the post processor might cause an error and the error is silently thrown by the generator.
    Nov 2012
    145
    Try sending it to desktop
    May 2009
    23
    thanks for the suggestions! I already had tried different other postprocessors (for Mach3 etc) and also tried different output folders, but it was still the same.
    but I made progress, when I reinstalled windows... no idea, what was the cause
    Mar 2004
    1661
    It was Windows then!
  1. Replies: 9
    Last Post: 02-21-2014, 02:55 AM
  2. Rhino 5, MadCAM
    By rdjay in forum MadCAM
    Last Post: 03-05-2013, 10:36 PM
  3. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
  4. Generate G code from rhino file
    By mredican in forum Rhino 3D
    Last Post: 02-24-2008, 12:51 AM
  5. rhino to madcam
    By daisydog in forum Rhino 3D
    Last Post: 07-31-2007, 07:15 PM
