586,024 active members*
3,835 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Torno Hitachi seiki 5NE-1100 turret fails
Results 1 to 7 of 7
    Jul 2014
    3
    Dear, I need your help I have a lathe hitachi seiki 5ne-1100 which does not obey the orders for the change of tools, if someone happened something similar please leave your comments, or if you can support me with the manual electrical wiring I would appreciate it a lot.
    Jun 2007
    61
    Re: Torno Hitachi seiki 5NE-1100 turret fails
    Did it stop working suddenly or did you buy it not working?
    How did you try to change tools?
    Ed.
    Jul 2014
    3
    Quote Originally Posted by atex57 View Post
    Ed.
    two months ago I was ok ', over time it started to fail more and more. Now it only works a couple of times in the morning. I've tried it in MDI, MANUAL and PROGRAM mode
    Quote Originally Posted by APTHOR View Post
    Could be the turret sensor broken, which caused it could not find the correct position to change the tool.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jun 2007
    61
    Can you use MDI and move it around?
    Try using MDI to send turret to X home, as in G28U0 then press the turret index button see if it indexes.
    Ed.
    Jul 2014
    3
    friends I did what you tell me and nothing.
    When the cnc lathe turns on in the morning, it works a couple of times.
    Then I try to move manually and by MDI and it does not move anymore, it does not work, the worst thing is that it does not alarm me.
    S.O.S
    Jun 2007
    61
    S.O.S
    Are you doing the complete homing process? Home X, Home Z, Home tailstock quill, and shifting headstock in MDI mode?
    My lathe started acting up sometimes then all the time. It was a bad connection on a cable in the back cabinet. Shut off the power then disconnect each cable and reconnect it, do this to all cables and try again.
    Ed.
  1. CNC HITACHI SEIKI 5NE turning center model 1100
    By yumuri in forum Techno CNC
    Last Post: 05-08-2020, 01:17 PM
  2. Hitachi Seiki turret problem
    By mjrkmr in forum Community Club House
    Last Post: 07-18-2013, 12:55 PM
  3. hitachi seiki 1020 turret set up error
    By freemanxxx in forum Uncategorised MetalWorking Machines
    Last Post: 07-20-2012, 03:33 PM
  4. HITACHI SEIKI HT25 TURRET ERROR
    By stevewotherspoo in forum DNC Problems and Solutions
    Last Post: 11-25-2011, 11:00 PM
