585,981 active members*
4,310 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Problem solved!!
    Jun 2014
    1780
    Problem solved!!
    I have been dealing with this for years, I finally figured it out! I use sprut 7 and have always had a problem with the simulation, sometimes it wouldnt show the toolpath simulation, it would run without showing where it cut into the stock, I finally discovered that selecting solid or 3d it would function as it should, just not if 5d was selected. What a Dunce!!!!
    I knew I wasnt the sharpest tool in the box but this is ridiculous!
    This should give a few of you a chuckle ha!
    mike sr
    Jun 2006
    3063
    Re: Problem solved!!
    SprutCAM seems to be one of those programs that needs you to hold your tongue a certain way in order to work correctly.
    Nov 2007
    2151
    Quote Originally Posted by MichaelHenry View Post
    Newest version works pretty well with few problems after you get it setup . Fusion360 seams to set the standard for huge average user base and development. Sprutcam looks to be developing more toward the high end multi axis robot systems.
    Jun 2006
    3063
    Quote Originally Posted by mountaindew View Post
    I'd agree that each newer versions seems to work better than its predecessors, but there are still some annoying problems. For example, the rapid speed defaults to 500 ipm and there seems to be no way to change that. I also struggle with lathe setups and coordinate system and the turret safe positions. The tool library still seems a big buggy too.
  1. Solved jerkiness problem
    By SpeedyDad in forum Momus Design CNC plans
    Last Post: 12-08-2011, 03:50 AM
  2. Transform Problem Solved !!!
    By mongo46538 in forum UG NX
    Last Post: 12-16-2009, 01:48 PM
  3. First cut problems: Problem Solved!!!
    By JeLC in forum DIY CNC Router Table Machines
    Last Post: 04-05-2009, 01:01 AM
  4. VF - 6 Problem solved.
    By JoBwan in forum DNC Problems and Solutions
    Last Post: 10-13-2008, 05:27 AM
  5. Problem Solved
    By widgitmaster in forum Community Club House
    Last Post: 06-20-2006, 07:14 AM
