585,690 active members*
4,554 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > how do i display block (line) numbers in memory on my HAAS VMC?
    Dec 2010
    sorry to ask such a rookie question but I'm a rookie..I have spent some time looking for the answer and can't find it. I sure didn't want to ask this one but..
    How do I display the block line numbers on my HAAS?
    the NC code has the block numbers but it doesn't show up in Memory during a program run. I had an interrupted run the other day and had to restart quite a bit earlier in the op than I wanted.
    2932
    Re: how do i display block (line) numbers in memory on my HAAS VMC?
    Are you sending programs to your control via RS232? If so, the DNC software may be stripping the block numbers.
    Do the block numbers on your code start with N?
    N0001 G00... etc.
    Dec 2010
    I am using a jump drive after Mastercam spits it out. The line numbers are there in the .nc code, they just don't show up in the controller. I think it's a setting but I can't find it.
    Quote Originally Posted by dcoupar View Post
    N0001 G00... etc.
    Dec 2010
    sigh...
    I figured this out.
    Mastercam does not export with block numbers - at least that I can find in the config settings.
    The MC .nc editor Code Expert shows line numbers but does not export them to the .nc file unless you manually insert them by hitting the "insert block numbers".
    Every day is another adventure in finding out something that sure would have been nice to know earlier.
    Mar 2008
    638
    Quote Originally Posted by tmickley View Post
    sigh...
    Hey! That's the story of my life!
  1. About position display with tool numbers
    By cevyil in forum Fanuc
    Last Post: 09-07-2016, 05:50 PM
  2. How to make block numbers to be shown on the screen?
    By dmitriy in forum Uncategorised MetalWorking Machines
    Last Post: 07-16-2011, 10:24 AM
  3. Block numbers and file sizes, heid 426
    By KevinV_MEI in forum Bridgeport / Hardinge Mills
    Last Post: 07-09-2011, 03:21 AM
  4. no line numbers
    By weirdharold in forum UG NX
    Last Post: 01-22-2009, 04:42 PM
  5. Block Numbers
    By phoodieman in forum Mastercam
    Last Post: 01-22-2008, 10:40 PM
