584,842 active members*
4,342 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Biesse Rover A 1836 G FT Post Processor
    May 2011
    27
    I have a "semi" working PP for the Biesse using Vertic Cut2d Pro. I had to edit the PP a bit to get it working and I can now make some cuts.
    I still need to change the code for the dust shoe, currently it stays up, does anyone know which variable controls the shoe.
    My Y-axis is also mirrored, I have tried to change the Y variable with a -1 in the post and this works for straight lines but not for arcs. Does any one know of a better way to mirror the Y in the post or what do I have to do to the code on the arcs to get them to line-up with the Y-1 fix.
    Will appreciate any help.
    Thanks.
    May 2011
    27
    Re: Biesse Rover A 1836 G FT Post Processor
    Nobody ... ?
    Does anyone maybe have the g-code and variable list for Biesse Rover CIX controller ? I have tried to change some of the variables to see if it will put the shoe down, but no luck. I got some information on the Vectric forum about a PCUF variable, but no matter where I add it to the code it makes no difference.
    Thanks.
    Thanks.
    May 2011
    27
    Ok, got the arcs sorted... When you change the Y coordinates in the variable section to -1 it works for straight lines. If you want the arcs to work to you have to invert the Clockwise and Counter Clockwise arcs too. If your Y is -1 you must use the G5 command with the CW and the G4 command with the CCW. You will also have to change the R value to -1. Normally CW is positive R but now you have to make it -R same with CCW the R now becomes positive.
    Like this:
    + Commands output for first clockwise Arc
    begin FIRST_CW_ARC_MOVE
    "[N] G5 R-[Radius] [X] [Y] [F]"
    + Commands output for clockwise arc move
    begin CW_ARC_MOVE
    "[N] G5 R-[Radius] [X] [Y]"
    + Commands output for first counterclockwise Arc
    begin FIRST_CCW_ARC_MOVE
    "[N] G4 R[Radius] [X] [Y] [F]"
    + Commands output for counterclockwise arc move
    begin CCW_ARC_MOVE
    "[N] G4 R[Radius] [X] [Y]"
    Apr 2019
    13
    Hi there,
    In the CIX file the hood position is controlled by the SHP variable.
    For a machine with variable step positioning this should be set to SHP=0, which is automatic, based on the length of the tool.
    Quote Originally Posted by bleker View Post
    Nobody ... ?
    Thanks.
    Thanks.
  1. Biesse Rover A 1836 G FT Post Processor
    By bleker in forum CamBam
    Last Post: 11-03-2018, 09:29 AM
  2. Post processor Biesse Rover 30
    By frank131313 in forum Aspire
    Last Post: 04-11-2017, 02:14 AM
  3. Need a post processor for BIESSE ROVER 4.40 FT
    By konkurts in forum Post Processors for MC
    Last Post: 05-19-2015, 05:02 PM
  4. Biesse Rover 346 Pallete Post processor
    By Raphiuz in forum Uncategorised CAM Discussion
    Last Post: 07-12-2013, 02:53 PM
