585,992 active members*
6,258 visitors online*
    Mar 2018
    70
    Aluminium-/Extrusion CNC Build
    just another build Thread for a CNC Router based on Aluminiumextrusion.
    Specs:
    25mm Linear rails on all axis,
    1605 Ballscrews for Y and Z Axis
    2005 Ballscrew for X Axis
    Motors: Nema23 High Torque Stepper, open loop ( They get replaced by 400W servos in future )
    The CAD Model:
    Building the Z Axis (drilling, drilling and yes.. even more drilling):
    Mar 2018
    70
    Re: Aluminium-/Extrusion CNC Build
    As you may notice, the motor and the ballscrew in the CAD is mounted to the front of the Z. On the actual build everything is mounted to the back.
    Attached Thumbnails Attached Thumbnails z-axis-assembly.jpg   z-axis-assembly-3.jpg
    Mar 2018
    70
    The Y Axis with the slides:
    The Motormountingbrackets for the Y axis are mostly finished:
    Mar 2018
    70
    If you don't have a drillstand, but profiles and linearrails:
  1. 450x300 Aluminium extrusion build from scrap/used parts
    By Nealieboyee in forum DIY CNC Router Table Machines
    Last Post: 07-26-2018, 08:36 PM
  2. 1300x900x170 aluminium extrusion build
    By jonnom in forum DIY CNC Router Table Machines
    Last Post: 11-06-2016, 12:50 PM
  3. 1st build, Aluminium extrusion based
    By andtfoot in forum CNC Wood Router Project Log
    Last Post: 11-20-2015, 03:46 PM
  4. Aluminium Extrusion CNC Router Build
    By joshendy in forum CNC Wood Router Project Log
    Last Post: 01-14-2015, 12:39 AM
  5. DIY aluminium and extrusion build BIG MACHINE
    By Usmanali in forum DIY CNC Router Table Machines
    Last Post: 01-08-2013, 06:24 PM
