585,744 active members*
4,241 visitors online*
IndustryArena Forum > CAM Software > Mastercam > dxf file not able to read
Results 1 to 7 of 7
    Mar 2008
    375
    I am trying to figure out how to read this file (DXF) when I bring it into mastercam for some reason I try to click on certain points and it will not let me choose them
    is there a process I have to go through in order for mastercam to read it
    also is there a way to check to make sure all entities are connected (kind of like purging the part)
    hopefully I mad some kind of sence
    thank you
    Jun 2005
    1729
    Re: dxf file not able to read
    You can import a DXF into Mastercam. You need to check your version of MasterCam and which version of AutoCad DXF is compatible.
    Russ
    Dec 2008
    3109
    Quote Originally Posted by cob View Post
    thank you
    Do any entities get imported ?
    .... yes... but not selectable.. check your mask settings.
    .... no ... DXF source has exported as a newer version that your Mastercam cannot read
    .. try exporting source DXF at a earlier release.....
    or... import into a later version of Mcam...say Mastercam2018
    as for entities being connected.... you mean "chained" ?
    what software is your source ?
    what are the features being exported ? ie polylines, text, lines/arc etc.
    some features export badly ie polylines import as small lines in the R12 translator option. Fonts and vector artwork have their own issues.
    Mar 2008
    375
    Quote Originally Posted by Superman View Post
    thank you for the replies
    so I am running mastercam 2018
    and yes for entities; some of them are not chained al the way so it will not let me do a toolpath
    some of the features that I am importing are fonts and some are just pockets but for some reason they are not chained all the way when I am importing a dxf file into mastercam.
    were do I go to check the mask settings?
    also I never use the R12 translator option , how and in what circumstance do use that option.
    thank you once again jut trying to figure this out
    Dec 2008
    3109
    ok...Mcam2018 should handle latest versions of most DXF translators.
    Font text is classed as a "drafting entity" ... it needs to be converted to it's basic items (lines, arcs and splines)
    ... use the "Break into Lines" r/h side of the drafting tab
    note.. some features of curved text will be splines .. any probs... try converting to arcs ( wireframe > trim > Break many pieces ... set create curves.. set a tolerance(play with this).. set keep ( switch to delete after checking diffs...BEFORE accepting the new geom.).... you may get chaining probs using this...
    to find breaks in a chain.. use analyse chain or contour
    ps
    goem that won't chain could be because of duplicate entities or maybe a branch point... read the tip that appears onscreen
    hope this solves your probs...
    Mar 2008
    375
    Unhappy Re: dxf file not able to read
    ps
    please bare with me this thing can be frustrating at times
    thank you again
    so I got this slot that is 4 inches long with a 1 inch radius on each end
    when I hit the shift key to see if it chained all the way it stops at the beginning of one of the radius.
    so I know it is not connected all the way,
    so I try to do the joint entities and it tells me that selected entities cannot be joined.
    how can I join them?
    thank you
    Dec 2008
    3109
    using the shift+ left click to select chained geom is a rough method to analyse probs...
    ... check for duplicates
    ... check for a 3D error..analyse distance b/w endpoints.
    ... check if not a spline.. trim function will not extend & trim a spline in the 1 action.. it has to be extended to past the intersection before being trimmed.
    you may need to redraw part of it
  1. pls, how to read the last line inside a file ?
    By deadlykitten in forum Okuma
    Last Post: 01-09-2019, 06:53 PM
  2. how to read dxf file ?
    Last Post: 01-11-2016, 04:18 PM
  3. File read Error?
    By atbjake in forum CamSoft Products
    Last Post: 11-26-2011, 10:06 PM
  4. V8 Read File Question
    By mjp in forum Mastercam
    Last Post: 02-27-2009, 05:18 AM
