586,005 active members*
5,044 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 250 milliamp fuse blows when VF2 is off
Results 1 to 12 of 12
    Aug 2012
    21
    Hello,
    I recently started having this issue of my 2013 VF2 blowing a small 250 milliamp (1/4 amp) glass fuse that is on one the boards. When this happens the machine will not power up when pressing the green power button. It happens when the machine is off and usually when it stays off for a few days. If I don't power it up for 3-4 days and than go to run it its dead and there is a small orange LED flashing in back that says blown fuse when ON. I replace the fuse and it runs fine without any signs of any issues. The machine has been moved a few months ago to a new shop. Never acted up at all in 5 years. After the move it ran ok for the first 2 months or so than it popped the fuse.
    Any guidance where to look for the issue would be appreciated. Haas service came out recently and replaced the internal clock battery and did a full update to newer software. No change in, still pops the fuse at random.
    Dec 2013
    5717
    Re: 250 milliamp fuse blows when VF2 is off
    I'm going to make a guess at what is happening. It sounds like the inrush to charge the capacitor in the power supply that the fuse protects is a bit high and when you power off for a few days, the capacitor is completely discharged and thus draws maximum current on power up.
    The quick fix for this might be to leave the machine powered up, the idle power draw isn't much and it keeps the electronics at a constant temperature. We leave ours powered up most of the time.
    You should check with Haas before doing either of the suggestions below.
    An alternative might be to install a 0.25 amp slo-blow fuse.
    Another alternative might be to install a 0.315 amp fast acting fuse.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2007
    2083
    blowing the 250 milliamp fuse I would check the power supplies and the electrolytic capacitors on the control boards
    is the mains supply voltage the same in both locations ?
    if the mains supply is higher in the new location the switch on surge current may be at the limit of the fuse
    did you replace the fuse with the exact same type - quick blow "F" verse slow blow "T" ?
    do you have a link to a PDF copy of the manual ?
    John
    Aug 2012
    21
    The fuse was a slow blow. I could only get regular fast acting locally so the last 3 fuses were fast acting. Today I can in and it was blown again, but finally got some slow blow fuses that I ordered and will replace so well see if that help.
    The current at the new place is a bit higher than at the last place, but the wiring and jumpers were moved to the right terminals for what is coming into this building. The old location had all 3 legs at 120v, and cross voltage was at 210v, but the new place where I am at has 2 at 120v and the 3rd leg is 240v. So cross voltage I think is at 244v.
    Mar 2007
    2083
    slow blow fuses are designed not to blow with the initial switch on surge current
    the fast blow fuses are not , so you may find every thing work OK when you use the correct fuse
    its possible the original fuse failed with old age
    when run near to there design limit the effects of temperature cycling as the fuse wire expands and contracts
    causes the wire to fatigue
    sometimes during the life of a product manufactures increase the fuses rating to stop nuisance fuse failures
    John
    Aug 2012
    21
    Quote Originally Posted by john-100 View Post
    John
    I got the fast acting fuses as that was the only thing I could get my hands on. So now that I replaced the last fuse that popped this morning with what belongs in there, a slow blow fuse we will see. Hopefully you are right and it was just a fluke or old age of the original fuse. I don't run any kind of production with the machine so leaving it on doesn't make for me as sometimes it doesn't get turned on for 3-4 days at a time.
    Thank you for your input so far.
    Sep 2013
    326
    Do you have any clue as to what the fuse is a part of or protecting? Any markings onboard? could also be any number of subsystems that fuse is wired into and the cold startup of that system. Just wondering as that is a pretty low value. Thinking interfaces and logic controls on my side. ???
    QUOTE=Dsmed;2233416]Hello,
    Any guidance where to look for the issue would be appreciated. Haas service came out recently and replaced the internal clock battery and did a full update to newer software. No change in, still pops the fuse at random.[/QUOTE]
    ericks Guest
    John
    I agree with this....
    Feb 2012
    115
    Is it the fuse after the mov? You could try a power logger to see if you are getting too high voltages.
    Dec 2013
    39
    Quote Originally Posted by Dsmed View Post
    check the control circuit and wiring , also check the control voltage
    Aug 2012
    21
    Wanted to give you guys a quick update. So far after installing a slow blow fuse the machine has not blown it. It has had a few days where it would sit off for 3-4 days and its been fine. Perhaps it was just time for the original fuse that was in there for 5+ years to go and as I mentioned the only think I could get in that amperage, size local was the regular fast acting. Once my order came in with the slow acting fuses I replaced it and the machine has been fine.
    Now I just need to come up with more stuff to make so it doesn't have to be shut off
    Mar 2007
    2083
    great news
    John
  1. Fuse constantly blows off
    By Denis77 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-15-2019, 12:52 AM
  2. G320(X) Runs motor immediately, blows fuse
    By jcarrz1 in forum Gecko Drives
    Last Post: 12-09-2016, 05:32 AM
  3. G540 Panel Build.. To Fuse or Not to Fuse
    By stingray_65 in forum Gecko Drives
    Last Post: 06-30-2016, 12:02 AM
  4. Spindle brake fuse blows intermittently
    By AndyB in forum Fadal
    Last Post: 08-20-2007, 04:14 PM
  5. Cemtroid1 controller board blows its fuse :(
    By dm.mcgahee in forum CNC Machine Related Electronics
    Last Post: 12-27-2005, 03:55 AM
