Skill level newby
Machine: Leadwell V21
Fanuc controller
I use G92 a lot for quick setups work fine my problem is when I go to use the normal G54 or G55 for my work piece zero`s in x and y the machine seems to have lost it`s zero home. I run the program and the machine doesn't go anywhere near where I setup my G54 part zero. I have tried shutting down , sending it home still doesn't work . Is there a procedure for resetting that I need to do I will need to be switching back and forth using G92 and normal G54 coding frequently . Any help would be appreciated.
Thank you
